bmxkelowna Posted July 4, 2007 Share Posted July 4, 2007 1993 turbo legacy so i finaly got around to wireing my FCD from free5ty1e the other day. so i took out the instructions and followed them step by step and once i was done i made sure all the wires were conected in the right places. i went to start the car to make sure it was in working order and both leds on the fcd lit up and my check engine light came on. code 45 - Pressure Sensor and Pressure Exchange Solenoid Valve and it wont go away. i compleatly unwired the fcd and its still there. and my car wont boost any more, as soon as it sees .5psi and up it just dies compleatly and will stall if you keep holding the gas. i replaced every thing on the strut tower with the boost controll stuff from my other legacy and no difference. i replaced all the vac line around there today just to make sure i never cracked a hose or some thing and its still doing it. so my question is, what can i do to fix this? did i wire it wrong and short some thing out? if so what would it be? a relay? fuse? any help would be awesome. thanks guys Link to comment Share on other sites More sharing options...
Olnick Posted July 4, 2007 Share Posted July 4, 2007 Fascinating. What's a FCD? Link to comment Share on other sites More sharing options...
86BRATMAN Posted July 4, 2007 Share Posted July 4, 2007 Its a fuel cut defencer. Eleminated that pesky 13 psi limit enforced by the stock ecu. Link to comment Share on other sites More sharing options...
Olnick Posted July 4, 2007 Share Posted July 4, 2007 Well, who'da thunk it? Thanks 86BRATMAN! Link to comment Share on other sites More sharing options...
Legacy777 Posted July 10, 2007 Share Posted July 10, 2007 did you get this figured out? Link to comment Share on other sites More sharing options...
davesuper Posted November 21, 2009 Share Posted November 21, 2009 hey man noob here having same prob with codes 22 35 45 on 93 ej22t manual boost controller??? help Link to comment Share on other sites More sharing options...
Legacy777 Posted November 22, 2009 Share Posted November 22, 2009 I'd suggest clearing the codes and then see what codes come back. http://www.surrealmirage.com/subaru/engine.html Link to comment Share on other sites More sharing options...
