GJTaranto Posted July 4, 2007 Share Posted July 4, 2007 On my 92 hot wire maf, I have 3 wires. A black one (GND), a signal wire, and a Red (+12V I believe) Is the red +12V supposed to be the same voltage as my TPS, or any of my other sensors and/or battery. I checked out my MAF voltage and got like +10V, checked out the TPS and got +12V. If they are supposed to be the same then my MAF isnt getting the correct voltage, anyone know where the MAF red wire connects to as far as its power source? Link to comment Share on other sites More sharing options...
Cougar Posted July 4, 2007 Share Posted July 4, 2007 My info shows the red wire of the MAF sensor goes to pin 17 of the ECU. The other wires are white and black. They also go to the ECU on pins 8 and 9 respectively. The info states that the voltage at pin 17 should be between 10-12 volts. Pin 8 should be between 0.1-0.5 volts. Link to comment Share on other sites More sharing options...
daeron Posted July 5, 2007 Share Posted July 5, 2007 http://ch601.org/engines.htm EA82 FSM files available there, includes the SPFI system breakdown, diagnostic and repair procedures. all the info you need. its in part 2. don't worry that its an 89 manual, its all the same as long as the parts are (ie, hotwire AF versus flapper AFM) Link to comment Share on other sites More sharing options...
