baccaruda Posted July 8, 2007 Share Posted July 8, 2007 either the wiring's crazy or I am! Let's find out! (Crikey! Let's get closah!) I added a second electric fan to my EA81T coupe, where the clutch fan used to be. No problem. I snagged an A/C relay from a Loyale because I wanted a strong-enough relay that was meant to be used underhood. The relay energizes with the red/black wire grounded and the green/white wire to power.. I THINK. The relay's blue wire gets juice and the blue/yellow wire powers the appliance in question. THE WEIRDNESS: I have the 2 hot wires all hooked up temporarily to the battery while installing. The blue/yellow powers the fan, which is grounded to chassis. I have the red/black relay wire spliced in with the car's yellow wire that is grounded by the thermoswitch. (the thermoswitch and stock fan work correctly.) With the car OFF, touching the green/white to [battery+] energizes the relay.. and the fan runs even though the engine is cool and the thermoswitch is open. ??? With the car ON, touching the green/white to [battery -] energizes the relay (and the fan still works).. ??? Can someone straighten me out here?? Link to comment Share on other sites More sharing options...
Gloyale Posted July 8, 2007 Share Posted July 8, 2007 The relay wires should be as follows. or at least this is how it was wired for the original AC application Blue=12v supply, constant(or ignition) Blue/yellow= 12v out to fan Red/black= 12v signal(from AC pulser/control unit) Green/white= ground What you want to do is wire Blue to constant fused 12v hook the Red/black to an ignition switched fused 12v so it has power whenever the ign. is on. Blue/yellow out to the new fans Pos. terminal And wire Green/white to the wire that grounds when the thermoswitch closes. Make sure you have it hooked to wire that is on the normally ungrounded side of the thermoswitch, so it has no ground until the thermoswitch closes the circuit. Link to comment Share on other sites More sharing options...
Gloyale Posted July 8, 2007 Share Posted July 8, 2007 baccaruda said: and the fan runs even though the engine is cool and the thermoswitch is closed. ??? Just a note: the thermoswitch is normally open at cool. It closes and completes the connection to ground at around 205 degrees. Fan is supplied with 12v by ignition and only runs when switch closes(hot) and completes ground. Link to comment Share on other sites More sharing options...
baccaruda Posted July 8, 2007 Author Share Posted July 8, 2007 whoops. thanks for this. I know this but the part of my brain that types what I know screwed up. I'm going to edit my original post for clarity. Gloyale said: Just a note: the thermoswitch is normally open at cool. It closes and completes the connection to ground at around 205 degrees. Fan is supplied with 12v by ignition and only runs when switch closes(hot) and completes ground. Thanks for your main reply as well. I'll repost later with results. Link to comment Share on other sites More sharing options...
baccaruda Posted July 8, 2007 Author Share Posted July 8, 2007 OK, I didn't want to work on my car because it's what I've been doing for the past 981347 weekends in a row, so I just fixed my diagram: thanks Gloyale! Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 8, 2007 Share Posted July 8, 2007 baccaruda said: OK, I didn't want to work on my car because it's what I've been doing for the past 981347 weekends in a row, so I just fixed my diagram: thanks Gloyale! quit being lazy Andy:-p Link to comment Share on other sites More sharing options...
daeron Posted July 9, 2007 Share Posted July 9, 2007 baccaruda said: OK, I didn't want to work on my car because it's what I've been doing for the past 981347 weekends in a row, so I just fixed my diagram: Is that a scientifical guesstimate on the number of weekends? Link to comment Share on other sites More sharing options...
Gloyale Posted July 9, 2007 Share Posted July 9, 2007 baccaruda said: Single pole??? Are the EA81 thermoswitches different than the EA82s? Link to comment Share on other sites More sharing options...
mikeshoup Posted July 9, 2007 Share Posted July 9, 2007 Gloyale said: Single pole??? Are the EA81 thermoswitches different than the EA82s? Yes. The EA81 grounds through the radiator As such, you have to make sure the ground wire is attached to it. Link to comment Share on other sites More sharing options...
