kiwi subbie Posted July 8, 2007 Share Posted July 8, 2007 just wondering if an Dual throat down draught carb 32/36 DGAV 32mm primary,36mm secondary webber carb work on ea71 motor? thanxs Link to comment Share on other sites More sharing options...
mcbrat Posted July 8, 2007 Share Posted July 8, 2007 just wondering if an Dual throat down draught carb 32/36 DGAV32mm primary,36mm secondary webber carb work on ea71 motor? thanxs yes, takes same adapter as the EA81. Link to comment Share on other sites More sharing options...
kiwi subbie Posted July 9, 2007 Author Share Posted July 9, 2007 were bouts do ya get an adapter from? will i have to rejet it? coz its of an 2L cortina engine thanxs Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted July 9, 2007 Share Posted July 9, 2007 Yes I think you would have to get it re-jetted since it came off of a different car. What size engine was in the car you pulled it from? Just thought if you got it from something with similar displacement you may have a good starting point. As far as the adapter goes, alot of people order from redline. I have seen several adapters in Australia for sale on ebay. There is a good weber thread on here,should answer any other questions you might come across. Good luck. Link to comment Share on other sites More sharing options...
mcbrat Posted July 9, 2007 Share Posted July 9, 2007 were bouts do ya get an adapter from? will i have to rejet it? coz its of an 2L cortina enginethanxs if it's still in decent shape, I'd try it with the jets already in it. I have a weber that came off a 1.9L Opel, and it ran awesome... I've even upped the jets on it since then... Link to comment Share on other sites More sharing options...
waimaks Posted July 11, 2007 Share Posted July 11, 2007 Keep an eye on trademe. I distinctly remember seeing an ea81/ea82 weber carb adapter plate on there, guy had been selling new ones, on there for months. More are bound to show up anyway. Link to comment Share on other sites More sharing options...
kiwi subbie Posted July 13, 2007 Author Share Posted July 13, 2007 hey man can ya keep out an look for me Link to comment Share on other sites More sharing options...
waimaks Posted July 13, 2007 Share Posted July 13, 2007 Heres one. http://www.trademe.co.nz/a.asp?id=108496338 Link to comment Share on other sites More sharing options...
erik litchy Posted July 14, 2007 Share Posted July 14, 2007 does the weber need the same fuel pressure as the stock carb? Link to comment Share on other sites More sharing options...
kiwi subbie Posted July 14, 2007 Author Share Posted July 14, 2007 yea thats an good point aye? Link to comment Share on other sites More sharing options...
suburpy Posted July 14, 2007 Share Posted July 14, 2007 pressure for weber no greater than 3.5 psi I think 2.o litre cortinas often had the double pump webers, they have some hidouesly wierd jetting I think 165 165 mains from mem. GD has written out many times the basic jet set to start with for a soob. Guy on Ebay aus has store called Gem Parts Australia sells many webers and has the adaptor plates as well as much more Link to comment Share on other sites More sharing options...
