robb1 Posted July 9, 2007 Share Posted July 9, 2007 hello...........gonna look at 98 outback today................................ automatic , 160,000 miles on it. two moon roofs ,,,must be special anniversary model? Any warnings or things I need to pay attention to like timing belts? Any replys that help are appreciated. Quote Link to comment Share on other sites More sharing options...
Suzam Posted July 9, 2007 Share Posted July 9, 2007 Is this a dealer or private sale. Private sale could mean all receipts available for a history which is worth it's weight in gold. Otherwise, check for tourque bind by driving in a tight circle clockwise and counterclockwise and make sure there is no fuse in the FWD socket under the hood and dirty or discolored antifreeze fluid in the radiator overflow bottle for indication of a blown headgasket are 2 that come to mind right away. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 9, 2007 Share Posted July 9, 2007 drive it a lot, those engines loose headgaskets fairly often (got a couple i could show you at my place). look for signs of overheating. actually...look for new headgaskets, it may have them and you can tell just by popping the hood. at that mileage 'id want the timing components checked. not just the belt, but the pullies as well should be inspected. many people will just throw a new belt on an be satisfied, that's not good practice for this engine and an excellent vehicle that could easily go another 100,000 miles. good luck! Quote Link to comment Share on other sites More sharing options...
nipper Posted July 9, 2007 Share Posted July 9, 2007 Look at the tires. They shold all be the same age. If one is newer then the others, be alert. Also take the car out to a parking lot. Automatic or manual do the same test. Driver in a tight circle on level ground. The car should be able to propel itself around the circle at idle (or a wee but of gas) ina nice smooth motion. If you feel any lurching, jumping or like a brake is dragging its has TB and will be a 800-1000.00 US repair. This would not condem the car if the seller agreed. I bought mine with TB for a very good price. nipper Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted July 10, 2007 Share Posted July 10, 2007 A dealer is going to want at least 5K ( ebay 3K). I would not purchase a Subaru with the 2.5 from a used car dealer that had over 130K. UNLESS some conditions are made. You want a 7 day 1000 mile warenty for any head gasket issues (overheating). Someone just got burned about a month ago on here. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 10, 2007 Share Posted July 10, 2007 NY Sate there is an implied 30 day warrenty, DOuble check that, but that would cover the car (r at least there used to be from a dealer). nipper Quote Link to comment Share on other sites More sharing options...
rzirker Posted July 10, 2007 Share Posted July 10, 2007 Primary check: Put your nose in the plastic overflow tank. Smell exhaust/oil/gas? Subtract $1500 from the price. (and even if you don't smell anything but antifreeze, you know those head gaskets will blow soon.) Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted July 10, 2007 Share Posted July 10, 2007 Definitely give it a good going over for all things mentioned incl torque bind and HG's. Figure in if it needs maintenance too, like plugs, wires, filters, fluids, etc. Unfortunately the NYS mandated warranty from a used car dealer doesn't apply for a vehicle that sells for less than $1,500 or whose odometer reading is more than 100,000 miles. Quote Link to comment Share on other sites More sharing options...
