RMVR53 Posted July 11, 2007 Author Share Posted July 11, 2007 Gloyale said: What did that kit include? If it had all the valve cover and timing cover gaskets, and all the cam,main and Oil pump seals that was a deal for sure. The dealer I go through ussually charges $30 just for the 3 oil pump seals and another $25 for just the valve cover gaskets. Cam and main seals are about $15 a piece. well...I don't rightly know whats in the kit yet as I haven't opened it. I asked for a head set (if it were English thats what you ask for) to do head gaskets out so I'm assuming (hoping) its all there...guess I'd better check. Bill Link to comment Share on other sites More sharing options...
Gloyale Posted July 11, 2007 Share Posted July 11, 2007 I know some dealersare starting to offer aftermarket brand pars for htese cars so perhaps they sold you a Fle-pro kit or something. Otherwise they had to piece toghether a kit because subaru doesn't sell "kits", everything has it's own part number and price. I know my dealer put's toghether oil pump reseal kits(TOD kit). They put the 3 seals in a bag toghether(still in thier seperate subaru # bags) and use a label that they print to mark it on the outside. Link to comment Share on other sites More sharing options...
RMVR53 Posted July 13, 2007 Author Share Posted July 13, 2007 ok my bad... Heads are EA82 and not in a box...Case stamping EA82 is in a box... dealer "head kit" has: factory head gaskets, 4 intake gaskets, 2 cam cover gaskets and cam cover seals/plugs (around bolts)..pretty much everything you move, remove or can damage during teardown. There is a small package of misc small o rings and washers...not sure what the o rings are for as I didn't notice anything coming out...wouldn't be valve seals would it? Bill Link to comment Share on other sites More sharing options...
stumpy Posted July 13, 2007 Share Posted July 13, 2007 stumpy said: Heads can not be swapped from one side to the other.Cam forward, exhaust ports down. Stumpy Nothing like posting with your head up your rear orfice! I was looking at the head assembly not at the bigger picture of the cam assembly coming off before head can be removed. Thanks to Gloyale's post it's nice to know I got the not interchangaable (At least with out mods) right. But that was luck and not of wisdom. Sounds like you got a decent price. I paid more for a complete set from thepartsbin, much more. I will remember this thread when I get around to tearing into the two motors I have with suspected HG issues. One ea82 and one ej22. Stumpy OT: Off to the Blue Mt. for a while. Will check back in some time in August to see the latest. Stumpy Link to comment Share on other sites More sharing options...
mikeshoup Posted July 13, 2007 Share Posted July 13, 2007 RMVR: What dealer did you go through? Go Subaru West wanted a ridiculous amount for a head set last time I checked into it... Link to comment Share on other sites More sharing options...
RMVR53 Posted July 13, 2007 Author Share Posted July 13, 2007 mikeshoup said: RMVR: What dealer did you go through? Go Subaru West wanted a ridiculous amount for a head set last time I checked into it... went through a friend's shop and he got it from Burt Sub on Arapahoe I think Bill Link to comment Share on other sites More sharing options...
idosubaru Posted July 14, 2007 Share Posted July 14, 2007 the Fel-pro permatorques are the way to go on the HG's. if you haven't opened the package yet, i'd return it or keep it for the other stuff if that's cost effective. i can't see them but the orings are probably fuel injectors seals and o-rings. the aftermarket kits come with valve stem seals (two sizes - exhaust and intake). the Subaru set may not come with those since they aren't absolutely necessary. don't forget the cam carrier oring, it's probably not in the head set and is a dealer only item (or http://www.thepartsbin.com carries them as well). Link to comment Share on other sites More sharing options...
