Renny_D Posted July 12, 2007 Share Posted July 12, 2007 It's been in the high 90s here all week and I had no AC. I jumpered the clutch just to see if the compressor turned and it turned fine. I checked the system pressure and there was none so using one of those r134 conversion kits I repressurized it but I think there may be some sort of blockage as it got to operating pressure with just one can. So now the ac switch will turn the clutch on and spin the compressor but I get no cold air out of the system. Any thoughts on what may be going on? The AC compressor failures I've dealt with in the past have all been of the frozen compressor belt sqealing type. Another thing I noticed is that when the clutch engaged there didn't seem to be any noticiable difference on the engine load? Do AC compressors fail and spin more freely? Please let me know if you have any ideas. Thanks Renny Link to comment Share on other sites More sharing options...
nipper Posted July 12, 2007 Share Posted July 12, 2007 reciever drier may have fell apart due to age. That will clog the system. You will need to have the system flushed evacuated and recharged. nipper Link to comment Share on other sites More sharing options...
DaveT Posted July 13, 2007 Share Posted July 13, 2007 Do you have a refrigeration gauge set? What are the 2 pressures? If the system was leaking (not working due to lost freon) for a long time, you need to vacuum the air out first. Link to comment Share on other sites More sharing options...
Prospeeder Posted July 13, 2007 Share Posted July 13, 2007 over full systems will just pump out hot air too. Sounds like u need to just replace the acumulator/drier and recharge it Link to comment Share on other sites More sharing options...
Renny_D Posted July 13, 2007 Author Share Posted July 13, 2007 Thanks for the feedback. I'll pick up a new receiver dryer. How exactly does one flush the system? I'll go get the freon sucked back out but what then? Renny Link to comment Share on other sites More sharing options...
nipper Posted July 13, 2007 Share Posted July 13, 2007 Somethings are better off left to a shop. DOnt just put in the drier and then let them flush it. They may flush it with it removed ( its been years so ive forgotten). They use liquid refrigerant, which you cant get. nipper Link to comment Share on other sites More sharing options...
Renny_D Posted July 13, 2007 Author Share Posted July 13, 2007 Well I checked pressure again today and it was low. I think the system had to cycle the fluid through it. I added more today to bring it up to pressure and was blessed with wonderful coldness. Today was the first time in two weeks that I've driven with all the windows rolled up and the radio turned down. It was really nice. Thanks again for all the feedback. Renny Link to comment Share on other sites More sharing options...
