superchargers
crazy D
Righto Dalton,
You will need to control your timing,
either electronically or by re-curving your distributor.
boost can be dealt with by either bypass blow off valves or a wastegate (external)
I have the bits.
PM me.
Matt
  Matty B said:
Righto Dalton,
I have the bits.
PM me.
Matt
hey matt, do you think we can talk about it here so we can spread the knowledge? afterall the board is all about info:)
pics, small words, and examples are great! lol :dead: haha
Of course,
I used a toyota SC14 blower from a 2.0 litre six cylinder toyota crown (JDM)..about $400 Aus on ebay.
These have a electromagnetic clutch to allow switching control.
I used a MSD boost timing master, it retards the timing by upto 15 degrees as the boost builds.
It was about $250 US, it stopped detonation completly.
Anything you do (if it is gasoline powered, not LPG) will need this control.
Piston will melt any other way.
It is possible to adjust the distributor curve, this will sacrifice off boost running quality, the MSD runs it perfectly both ways.
Keep the boost mild, ie under 10psi or drop the compression by installing EA82T pistons and wind it up.
Intercool it if you can, I found the throttle body best positioned before the Supercharger.
Belts slip, use a serpentine system if you can, 5pk or 6pk multirib.
Wrap as much around the pulleys as you can using idlers.
It will need more fuel, a fuel injected platform from the start will help, there are a few carbs that can do the job, hard to find though.
Theres more, my brain is full.. later
Nup Crazy, that won't work.
The SC14 I used only made 5-6 psi with the EJ22, maximum.
The smaller unit would only give you 2-3psi I am afraid.
You could ditch the clutch and try spinning it faster but then heat becomes a problem and I see you live in Arizona...
I bet you ten beer tickets that it is hotter there than here in Tasmania.
Ebay will find you one.
