GLENN"S854x4wagon Posted July 14, 2007 Share Posted July 14, 2007 I need to find a place in southern cali that has SUBARU PARTS FOR MY 85 GL 4X4 WAGON MY AUTO TRANS WONT SHIFT Link to comment Share on other sites More sharing options...
86BRATMAN Posted July 14, 2007 Share Posted July 14, 2007 You can swap a 5spd d/r tranny in there. All the info you need for that swap is here in the forums. Try posting in the wanted section of the classifieds for either option. Link to comment Share on other sites More sharing options...
s'ko Posted July 14, 2007 Share Posted July 14, 2007 I need to find a place in southern cali that has SUBARU PARTS FOR MY 85 GL 4X4 WAGON MY AUTO TRANS WONT SHIFT Check craigslist. There is a guy who is selling brand new trannies. I think cyberbackpacker posted about this. BW Link to comment Share on other sites More sharing options...
misledxcracker Posted July 14, 2007 Share Posted July 14, 2007 There were a couple auto 4x4 ea82's over at the pick-your-part in wilmington, if you're willing to drive and pull it... another option Link to comment Share on other sites More sharing options...
john in KY Posted July 15, 2007 Share Posted July 15, 2007 Might want to check the vacuum modulator before replacing the transmission. If it stops working you end up with no up shifts. Link to comment Share on other sites More sharing options...
GLENN"S854x4wagon Posted July 23, 2007 Author Share Posted July 23, 2007 i replaced the transmission module cuz it was smoking white smoke ordered 1 and it did'nt work or i mean shift so i got enother one same thing Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 older transmissions operate like an hydraulic computer. They are constantly balancing out throttle pressure (modulator) vs govenor pressure. Without either one of these the car wont shift properly. Check your govenor, it may be bad or stuck. nipper Link to comment Share on other sites More sharing options...
MilesFox Posted July 23, 2007 Share Posted July 23, 2007 if you find the governor is bad you can swap in anotherone from any 3spd auto trans wether it be 2wd or 4wd Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 if you find the governor is bad you can swap in anotherone from any 3spd auto trans wether it be 2wd or 4wd And its something thats not uncommon to go bad on a auto tranny. nipper Link to comment Share on other sites More sharing options...
daeron Posted July 23, 2007 Share Posted July 23, 2007 older transmissions operate like an hydraulic computer. They are constantly balancing out throttle pressure (modulator) vs govenor pressure. Without either one of these the car wont shift properly. Check your govenor, it may be bad or stuck. nipper holy cow, you have no idea how much that simple explanation made things that I haven't really quite grokked in years and years of trying, go *click* in my head. Really loudly. Thank you. Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 A better explination without me doing a lot of typing http://auto.howstuffworks.com/automatic-transmission6.htm Your welcome (i love teaching, hate typing) nipper Link to comment Share on other sites More sharing options...
daeron Posted July 23, 2007 Share Posted July 23, 2007 A better explination without me doing a lot of typing http://auto.howstuffworks.com/automatic-transmission6.htm Your welcome (i love teaching, hate typing) nipper I am rather astute at both, if I do say so myself.. (that is why so many of my posts extend so long.. I suspect that just about any of us who type the "books" here all the time can probably type at least 50-60 WPM) but I have always mostly ignored automatic transmissions and it is a sheer accident of fate that I own one now. What I am saying is, I have been far from motivated to learn about something I never wanted to use, much less have to diagnose or repair. Thanks again for showing me the light anyhow, since I (regretfully) need to know these things. Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 I am rather astute at both, if I do say so myself.. (that is why so many of my posts extend so long.. I suspect that just about any of us who type the "books" here all the time can probably type at least 50-60 WPM) but I have always mostly ignored automatic transmissions and it is a sheer accident of fate that I own one now. What I am saying is, I have been far from motivated to learn about something I never wanted to use, much less have to diagnose or repair. Thanks again for showing me the light anyhow, since I (regretfully) need to know these things. The new computer controlled trannies do away with a lot of the parts that would cause a tranny to fail. The govenor (replaced with the VSS), modulator (ECU input) and most the valve body (solenoids) are gone. Clutch bands are disapearing (replaced with clutch packs). The basics of automatic trannies have been around since the begining. The model A ford had a planetary gear set. Those three pedals on the floor were for the brakes, low and high gear (press it in you were in low), and reverse. Throttle and ignition advance were on the steering wheel hub. http://www.barefootsworld.net/ford-t-4-beginners.html nipper Link to comment Share on other sites More sharing options...
GLENN"S854x4wagon Posted July 25, 2007 Author Share Posted July 25, 2007 THANKS GUYS the govener was sticking took it out and messed with it then put it back in now its shifting thank you all again Link to comment Share on other sites More sharing options...
