Subarutex Posted July 17, 2007 Share Posted July 17, 2007 My EJ22 swapped wagon has some occasional hesitation which more and more seems to be from a fuel delivery issue. I'm now starting to investigate the fact that my gas tank seems to get heavily pressurized, and if this could be a cause of my hesitation issues. So... I have the gas tank vent open to atmosphere at the engine bay with a little filter on it. Filter is brand new, and is not clogged. Where else should the tank be vented? Any other ideas on why my gas tank is getting so pressurized? Link to comment Share on other sites More sharing options...
monstaru Posted July 17, 2007 Share Posted July 17, 2007 heat?it has been damn hot in our parts lately........ Link to comment Share on other sites More sharing options...
Subarutex Posted July 17, 2007 Author Share Posted July 17, 2007 While the heat hasn't been helping... The car has always pressurized the tank since I did the EJ swap. Link to comment Share on other sites More sharing options...
pinksock Posted July 17, 2007 Share Posted July 17, 2007 dont know if its related but here at my dealership it seems like we fix alot of older Nissan's with this same problem. They are fixing the problem with new vented gas cap's. Anyway a cheap fix, maybe worth a try?? Tony~ Link to comment Share on other sites More sharing options...
86ruguy Posted July 18, 2007 Share Posted July 18, 2007 the pressure in the tank is not what is causing your car to hesitate. Did you hook up a check engine light? pull codes, if any. my old swap car had an issue with the MAF until I replaced it. Link to comment Share on other sites More sharing options...
baccaruda Posted July 18, 2007 Share Posted July 18, 2007 have you swapped gas caps yet? Link to comment Share on other sites More sharing options...
MilesFox Posted July 18, 2007 Share Posted July 18, 2007 the little metal line that comes up from the driver side framerail is the vent for the vacuum canister. this would connect to the skinny line (of the fuel lines)on the mpfi intake Link to comment Share on other sites More sharing options...
