Announcements
Boooost!
More info to come, but the short of the story:
Installed a MBC (manual boost controller) tonight. The homemade type of course... The car was peaking ~17psi. Yes I KNOW this is to high. lol.... But I didn't say I held it there. I re-adjusted and it's around 11psi-12psi now. That's a little more manageable. lol....
But the intersting thing is, even the couple of times that I let it get up very high, the car did not show any sign of fuel cut, nor was there any audible detonation! My rx is a '88 with an '89 motor, so it should definatly have the electronic cut according to everything I've read. Who knows!
More updates when it's dialed in a little more tomorrow.
  • Replies 74
  • Created
  • Last Reply
Top Posters In This Topic
The fuel cut protection is on a timer circuit.
Try holding it at 12 or so for more than four seconds.
How does Emril say it "BAM"
MAF voltage following clamping circuit under design, need +5Vdc ref voltage.
Watch the engine temps. I have never seen a lean condition running those pressures but .....
Do your engine a favor get an EGT gauge
good luck
good luck
Thanks for the reply! I re-adjusted this morning, and it's running right around 12psi. The car is strong! OMG! lol... I think it did hit the cut though. Somewhere about 12psi & 6krpm. It was right as I was just before I let off the gas to slow down, so I'm not sure that's what it was. I'll have to investigate later. hehe... EGT and A/F are in the near future for sure. It's nice now, as it's cold outside. :banana:
Originally posted by XSNRG
What's EGT? Exhaust gas temp? Tell me how it works please:-)
Yes EGT=Exhaust Gas Temp
A/F= Air/fuel mixture of course.
The egt has a probe that goes in the ehxuast and measure the exhaust temp. Pretty simple eh. ;) lol....
I went from this page: http://www.geocities.com/chmwatson/FAQs/mbc.html
but I bought slightly different parts. I spent a total of $9.00 and an ink pen. lol..... If you want to get all the parts in one location (ie home depot, lowes), you can get a female air hose quick disconnect for the ball bearing. That's what did it for me. I kept thinking, now where in the hell am I going to come up with one little ball bearing. lol..... Plus you'll have 3 more bearings for making more controllers. hehe.... Sort of like $9 in parts for the first, and about $6.50 in parts for the next 3! lol....
pleiades You have not said you have held it on 10 psi or above for over five seconds ? Find a long hill and in an upper gear get it over ten psi and hold it there for atleast five seconds. Please report your findings.
I have not noticed it doing the fuel cut when holding it in for 5 or more seconds, however, the turbo does seem to fall off about 6k by the time you hit 3rd gear.
WJM is here, we'll go test it some more. hehe... :headbang:
5th gear accelerate on freeway for 20 seconds. Gauranteed to hit fuel cut.
Skip... are we sure we need a 5vref? Can't we just use the ref signal that is already going to that, even if it is less voltage?
:: I know nothing about electronics ::
PS, mines almost done... hows about yours?
well we went back out a bit ago. The car seems to loose power, but it doesn't seem to be the fuel cut. If I am correct, the fuel cut is a hard rev limit type power loss. I'm just getting to a point where it's like hitting a wall. Just no more power.
The over boost control feels like the ignition switch was turned off for only 1/2 second.
The driveline shock is severe.
The engine will then pull like it was until the timer times out again.
Your MBC may be to blame as it may be allowing waste gate creep
i.e. leaking some of the pressure through and causing the waste gate to open slightly.
My wagon pulls like crazy right up to 7 k RPM.
Ask Trogdor he has seen it do this.
I recco you put your boost gage on a tee fitting in your waste gate control line, see if you get any pressure before you get to the "dialed in" pressure.
I experimented with many home made MBCs the spring is the second most critical component right after the ball / seat.
Good luck.
Tex, my parts have not arrived yet??!! Am calling Jameco today.
Yes we need the 5Vdc ref to calibrate the op amps for the proper control (clamping) voltage, I also ordered an 5volt VR IC (voltage regulator), BTW, no foolin' I honestly don't kow much about 'trisy either.
Thanks for the input Skip! I definatly know that I need to polish the setup a little. I will move the boost gauge location and see what I find there. By your description of the fuel cut, the car is most definatly not hitting the fuel cut.
Originally posted by pleiades
No problem. hehe.... If you need a bearing, I've got three more.
Actually, Lowe's didn't seem to have any ball bearings, so I took your suggestion and picked up a female air hose coupler. Now how do I get the freaking bearings out of it? :cornfuzz:
I picked up everything I needed PLUS I had to buy a tap set and teflon tape (as I had neither) and STILL came out for under $40 after tax! :D (The tap set was $26 by itself!)
Also what's the deal with drilling the 1/32" hole in those instructions. First of all, I don't understand what the hole does. Secondly, I couldn't even find any 1/32" drill bits, so I assume he actually meant 1/16" (the smallest I could find in the store and I already have bits that size).
Man, you're making it too complex! lol.... Do you want me to make you one? I can do it for about $7. I used the dremel to cut the 'sleeve' off of the female air adapter, then the bearings just fall right out. I also didn't go with exactly the same parts as the diagram. I guess I'll build another one this weekend and do a writeup with pictures. The parts I went with seemed a little more plentiful. lol... Shane, What did you do for a spring? I think that's the only department where mine needs a bit of improvement.
Too complex!? With all new parts (except for the spring where I'll probably go the "pen" route for the time being unless I can find a better substitute) and ignoring the tap set and teflon tape roll (which are more tools/supplies than parts), I only paid $9.17 before tax and some of those prices are for multiple items (i.e. 4 bearings, 4 nuts and 2 bolts). So I'd say I'm getting by quite cheaply here... :D
Ahhh...that makes sense. Dremel time! :burnout:
heh would ya mind makin me one of them contraptions and ship it to me?
I don't have a tap and die set, so it'd cost me more than i'd wanna spend to do it... i've seen those on ebay for about $15 shipped, but would rather get one from someone on the board so i know who put it together.. versus, ed in the bayou in the usa somewhere :lol: know what i mean.. lol
Ok, you can have the one I build for instructional purposes. PM me your mailing info. I'll probably build in on Saturday. If I send it via us postal, the total should be ~$9 for the parts and postage.
