Goatboy Posted December 3, 2003 Share Posted December 3, 2003 I assume the cage nut or welded nut on the inside broke off. Is there anyway to get to it with out cutting a whole in the bottom of the car?? I'm really tired of my seat rocking when I drive. --GoatBoy-- Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 3, 2003 Share Posted December 3, 2003 which bolt?? front left or right or rear left or right? you may have to resort to breaking off the bolt head, then yanking the seat AND carpet then replacing the nut. (if there is a nut, some of the holes may just be threads in the floorpan) I'm willing to help someday that I'm free after I finish my college project and my Loyale tranny swap Link to comment Share on other sites More sharing options...
Goatboy Posted December 3, 2003 Author Share Posted December 3, 2003 It is the front left, by the door of the drivers seat. Not the one on the tunnel. I'm pretty sure it was a welded nut or a cage nut. I felt it break loose when I was trying to tighten it. --GoatBoy-- Link to comment Share on other sites More sharing options...
ShawnW Posted December 3, 2003 Share Posted December 3, 2003 Fix depends on what is left. If the nut is still in there but the threads are trashed, try putting a longer bolt of the same thread thru and putting a nut on the nut side thus clamping new threads. If the nuts isnt there then you have a bigger mess but it might require a fender washer and a new nut, etc. If you can see the ground thru the hole then you have one option, if you cant theres more. Link to comment Share on other sites More sharing options...
Goatboy Posted December 3, 2003 Author Share Posted December 3, 2003 It doesn't go down it goes front to back. From what I can tell there is no access to the backside where the nut is. Thats why I hit the board up to see if anyone else has seen this and if they knew an easy fix. I guess I could get a really large machine scew and then just knock the bolt out and thread the big screw through the hole. Cuz I don't think there is anyway to get to that nut on the other side, not with out cutting a big hole in the metal on the back side to open that area up for access. --GoatBoy-- Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 3, 2003 Share Posted December 3, 2003 Hmmm I'm trying to remember... its been a while since ive removed my carpet/seats... But there may be some access in there, but not much. I know its a raised rib of some sort thats welded to the floor. You may need to remove the rear seat heating ducting (black plastic stuff) after yanking the carpeting, but I'm pretty sure you could get down in there to fix that nut. Link to comment Share on other sites More sharing options...
Goatboy Posted December 3, 2003 Author Share Posted December 3, 2003 Your correct it is the raised rib. If it comes down to pulling carpet and other things apart I will just do like my previous post, drive a big rump roast screw in there. --GoatBoy-- Link to comment Share on other sites More sharing options...
edrach Posted December 3, 2003 Share Posted December 3, 2003 Not an uncommon problem. Remove the seat and get the carpeting out of the way. Drill a hole in the rear portion of the raised rib and then install a large bolt, large flat washer, lock washer and nut (locktite wouldn't hurt either) to hold the seat in place. It's awkward to keep then nut from turning when tightening the bolt, but it's easier than welding if you don't have the welding equipment. Link to comment Share on other sites More sharing options...
XSNRG Posted December 3, 2003 Share Posted December 3, 2003 Did you get the old one out yet? I had this happen to me the other day. I used a air powered die grinder with a 2" cut off wheel to cut the bolt head off. Link to comment Share on other sites More sharing options...
Goatboy Posted December 3, 2003 Author Share Posted December 3, 2003 The old bolt is still in there. I have a dremel tool. I'll just cut it off with that. I really don't want to rip up the carpeting. I think I'll just cut the bolt off and then run a bigger screw in there. Thanks for all the input guys! --GoatBoy-- Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 3, 2003 Share Posted December 3, 2003 It only takes like an hour to yank the front seats, console and carpeting. Its not that hard. Of course cutting the bolt off would add some time. Maybe try the bigger bolt idea first... if that fails then it may be worth yanking the interior in an afternoon. Link to comment Share on other sites More sharing options...
