GLENN"S854x4wagon Posted July 21, 2007 Share Posted July 21, 2007 My 85 Subaru gl wagon 4x4 A/T was smoking white smoke. so i changed my transmission moduler and the new 1 has a little screw. Me and a friend who is a mechanic both played with that ---- beep screw . and now it wont shift . i put into drive it is in first but wont shift to 2nd . I can put it in 2nd manually and when i get to 4000 RPM's i put it into drive and it wont egauge to drive can some one help i only have 103,000 miles on it. And one shop told my its to old for me to touch he's a a--hole cuz sub's rule Link to comment Share on other sites More sharing options...
DaveT Posted July 21, 2007 Share Posted July 21, 2007 so i changed my transmission moduler and the new 1 has a little screw. Me and a friend who is a mechanic both played with that ---- beep screw . I kind of wondered what that screw might do. I wouldn't mind adjusting the shift points a little. Maybe it got turned all the way one way -> don't shift? Is the old one so bad you can't do a quick test drive? Are you aware of the little pin that goes into the modulator? It usually stays in the transmission, but nothing really holds it there... Link to comment Share on other sites More sharing options...
misledxcracker Posted July 21, 2007 Share Posted July 21, 2007 Sounds like the pin for the modulator is missing, or you didnt check the fluid correctly after the modulator swap and its not at the correct fluid level. I say ditch the automatic all together Link to comment Share on other sites More sharing options...
Cougar Posted July 21, 2007 Share Posted July 21, 2007 If the smoke problem isn't cured still then replace the PCV valve. Link to comment Share on other sites More sharing options...
GLENN"S854x4wagon Posted July 22, 2007 Author Share Posted July 22, 2007 the pin is fine and the fluid level is great Link to comment Share on other sites More sharing options...
misledxcracker Posted July 22, 2007 Share Posted July 22, 2007 Smell the ATF. Does it smell like gear oil? If so, ditch the slushbox. Link to comment Share on other sites More sharing options...
MilesFox Posted July 22, 2007 Share Posted July 22, 2007 take a look at the governor, the cup shaped thing on the passenger side of the transmission. take i t out an apart and clean it rather well. make sure the gear is not "apple cored" also, ther eare 2 dipsticks on the transmisson, one foe ATF !! or !!! and one on the top for the front diff, which takes your regular gl-5 gear oil. the governor threads into the diff and is centrifugal activated realtive to rolling speed of the front drivetrain there should be an article on the procedure, search usrm "governor shaft" Link to comment Share on other sites More sharing options...
GLENN"S854x4wagon Posted July 23, 2007 Author Share Posted July 23, 2007 the gear oil looks a little high i herd tha sometimes the tranny fluid leaks into the gear oil is that true Link to comment Share on other sites More sharing options...
misledxcracker Posted July 23, 2007 Share Posted July 23, 2007 Exactly why I asked you to smell the automatic transmission fluid. If it smells like gear oil, the seal between the front differential and the transmission either seeps or blows. Usually happens when either oil (atf/gear oil) is ran really low, or previous modulator failure, resulting in the transmission being ran on low or no ATF at all for some time, which is no good of course Link to comment Share on other sites More sharing options...
