The Dude Abides Posted July 21, 2007 Share Posted July 21, 2007 Im toying around with the idea of cleaning up the rust on my car before it consumes it. How do you remove the side trim on a wagon ea82 Ben Link to comment Share on other sites More sharing options...
The Beast I Drive Posted July 21, 2007 Share Posted July 21, 2007 They are plastic clips, they break unless you get up inside the body to pop them loose with pliers or something Link to comment Share on other sites More sharing options...
Tom63050 Posted July 21, 2007 Share Posted July 21, 2007 The Beast I Drive said: They are plastic clips, they break unless you get up inside the body to pop them loose with pliers or something I'd take off the inner door panel, cut through the plastic, and try working on them from that side. To get the door panel off, you: 1. remove the inner mirror cover--pops off B. remove the door latch plastic plate/cover--one screw, or maybe it pops off too, I forget 3. remove the armrest--two screws under the little covers--pop the covers out with a flat screwdriver d. lots of little fasteners hold the door panel on--just pull the panel away, most will still be OK 5. pull the door panel up and away, and separate the electric window connector Link to comment Share on other sites More sharing options...
subaruguru Posted July 21, 2007 Share Posted July 21, 2007 im just gonna remove my trim all together on my 82 i think it will look cleaner if any one is interested in it they can have it for oh say 20 bucks its a little dinged and bent but its good am keeping the crome bumpers and rings for the tail lights thats just style ther Link to comment Share on other sites More sharing options...
MilesFox Posted July 21, 2007 Share Posted July 21, 2007 85 and 86 trims will be glued on. 87 and later they will clip on and the doors will have holes in them Link to comment Share on other sites More sharing options...
The Dude Abides Posted July 21, 2007 Author Share Posted July 21, 2007 lets say i happen to bust them off where could i maybe get replacements does anyone know ben Link to comment Share on other sites More sharing options...
GJTaranto Posted July 21, 2007 Share Posted July 21, 2007 I am also wanting to take them off. What could I fill the holes with though? Its my wifes car. So it has to have something (she wont drive around with holes along her car) For the sake of detailing it I would like to take them off and stop the rust underneath them. Link to comment Share on other sites More sharing options...
TomRhere Posted July 21, 2007 Share Posted July 21, 2007 GJTaranto said: I am also wanting to take them off. What could I fill the holes with though? Its my wifes car. So it has to have something (she wont drive around with holes along her car) For the sake of detailing it I would like to take them off and stop the rust underneath them. Would be best to weld holes over, but bondo will do the job. May last long time, may need to be repaired, again if/when bondo is used. Depends.... Link to comment Share on other sites More sharing options...
hyrysc Posted July 22, 2007 Share Posted July 22, 2007 Welding would be probably the best bet, but if you don't have a welder, I have used that "liquid Steel" stuff that sets up very hard, put that in there and squeeze it tight, and when it set up, sand it smooth. Link to comment Share on other sites More sharing options...
zyewdall Posted July 23, 2007 Share Posted July 23, 2007 The Dude Abides said: lets say i happen to bust them off where could i maybe get replacements does anyone know ben Dunno. I think you could glue them back on with silicon glue if you break the clippies. Z Link to comment Share on other sites More sharing options...
