Thanks. We've tried looking in our repair manual but no luck there either...maybe someone will read this and know what we're talking about...appreciate the reply.:)
Sounds like the switch for the shift interlock system is shot. Unfortunately, I don't know of anyone that's had to replace it so I don't know the method for doing so.
ok here you go. Its a simple system. You either have a bad relay or solenoid in the system.
YOu should hear a click when you have the car on, foot on the brake, and press the gear shift button. If you dont there lies the problem.
http://www.ultimatesubaru.org/forum/showthread.php?t=46496&highlight=Key+Stuck
maybe that will help
http://www.subaruoutback.org/forums/showthread.php?s=&threadid=7763&highlight=interlock
nipper
Nipper,
Thank you...can't quite get what you mean though...we definitely do not hear the click anymore but I searched through the posts you hyperlinked for me and I'm not finding a solution...except to take apart the gear shifter assembly around it...it works when we press the button at the base...could something have come apart under the gear shift assembly?
Angel :)
nipper
Nipper,
Angel :)
Yes sometimes the plunger pops out of the solenoid.
im sure somone else will chime in with a better explination, its happesn a few times a year here. Look on the outback board too.
nipper
