wrcRabbit Posted July 24, 2007 Share Posted July 24, 2007 Well, I will try to explain it as best as I can :-\ . I have a 2003 Impreza WRX Sedan, 78,000 miles on it...Well, the electronic piece on my rear right window is not working properly, to say the least. When the bezel(the piece that you push down or pull back with your finger to control the window on the arm rest on the door panel) is attached to the electronic piece(a plastic part with two springs side by side inside of it, which has ball barings under them and two, what it looks like, copper pieces) it does not work. But if you take off the bezel it works fine, unless you put pressure on the plastic piece. Anyways, I have taped it off so I can control it from my driver's door. I am guessing that it is just grounding out when the bezel is on it, for what ever reason. So, I figure no big woop, so my back seat passenger can't roll down his/her/it's window. I have totall control ...unless they switch seats. I am just wondering if anyone else has had this problem or knows how to fix it or knows what it even is... Thanks... Link to comment Share on other sites More sharing options...
Legacy777 Posted July 24, 2007 Share Posted July 24, 2007 Sounds like an odd problem. The switch may need to be replaced. You may also want to try posting on http://forums.nasioc.com/forums and see if anyone else has experienced this problem. Link to comment Share on other sites More sharing options...
wrcRabbit Posted July 26, 2007 Author Share Posted July 26, 2007 Thank you, will do that Link to comment Share on other sites More sharing options...
