EA81 clutch fork return spring
Did i mess up? I just read another post and it sounds like there is supposed to be a clutch cable return spring so that the TO bearing is not riding on the clutch fingers all the time. Well the way mine is set up right now i have the TO bearing riding on the clutch fingers all the time cause i thought that was how it was designed to be. I didnt see any spring that was supposed to return the clutch fork to position other than the clutch fingers.
The spring attaches to the fork lever at the cable end, running between the end of the fork lever and the bell housing, so its easy to replace.
