Supercharger idea. Need help with parts
So I am considering building a supercharger setup.
Here is the catch. I would like to make it modular so I can put it on either the EJ18 BRAT or my EJ22 2k OBS.
the EJ18 is from a 1995 OBDI car.
EJ22 is a OBDII car.
I have a spare intake manifold for an EJ18 sitting around and IIRC it will bolt up to the EJ22 w/no problems.
Is this doable?
Is there a aftermarket computer that I can switch profiles for both engines? I am looking at 5-10 pounds of boost so nothing insane. Just a little more pep.
BW
Sup Bosco. You'd also want to put bigger injectors on both cars and have a way to cut fuel pressure when running without it. If I were you I'd start with the brat, and then try to adapt it to the OBS once you have the kinks worked out.
  porcupine73 said:
There was that post some months back from someone who put an old Mercedes I think it was supercharger and fed that into a turbo on a Legacy I think it was...
Yeah that's Douglas Vincent.
With the number of motors he's gone through I wouldn't exactly call it "successful."
Hey now! :grin:
EVERY one was succesful! It worked didn't it? Every motor was usually lost when I decided to run WAY TOO MUCH NITROUS through it without EM. And then I got EM and proceeded to run even more nitrous through. haha
Boost is boost. You tune for it or blow a piston. And when you boost NA motors, you pop pistons fast if you are greedy.
Sko, I will reply with a though out message soon.
Doug
