check engine - error code listing
Hi folks.
My CEL is lit, so I stopped at an auto parts store and got the error codes extracted.
Two of the error codes are P0130 and P0136 (O2 Sensor Circuit Malfunction). One of them is "Bank 1 Sensor 1", and the other is "Bank 1 Sensor 2". In addition, there are "Fuel Air Metering" errors, which I assume are being caused by the bad O2 sensors.
I just wanted to verify that these errors are caused by bad O2 sensors, and that replacing them should be my first response. Or could these errors be caused by some other problem?
Thanks.
