Snowman Posted December 4, 2003 Share Posted December 4, 2003 HELP!!!!!!! 1991 loyale Died all of a sudden. Checked spark, it's good. Checked for fuel at filter, no pressure because fuel pump isn't running. Pulled fuel pump and tested it, and it works just fine. Whipped out the Fluke and tested the power to the fuel pump. When the key is first turned on, it reads about ten volts, then drops to zero after about one second. When cranking, no voltage appears. What demons have possessed this car? Could it be the fuel pump relay? The computer? I've got spares of both, but they are 800 miles away, so I need to find out what's wrong. Link to comment Share on other sites More sharing options...
calebz Posted December 4, 2003 Share Posted December 4, 2003 If you are getting spark, its probably not the computer. Fuel pump relay is a good bet. If its easier for you, I will send you one.. save you an 800 mile trip. Link to comment Share on other sites More sharing options...
Snowman Posted December 4, 2003 Author Share Posted December 4, 2003 Thanks caleb. I don't think I'll have a chance to check it out until next monday, but I'll PM you if I need one (it's not terribly important that the car is running right now, and I'll be making the trip for Christmas anyway. I may still take you up on that though, because I might need the car running sooner than that.) Link to comment Share on other sites More sharing options...
calebz Posted December 4, 2003 Share Posted December 4, 2003 Cool. I have 3-4 of them floating around in my garage. Just let me know. Link to comment Share on other sites More sharing options...
MilesFox Posted December 4, 2003 Share Posted December 4, 2003 if you get vols and it quits, sounds lile the relay is working. when you turn the key to run position, it kicks the pump on for a few seconds. after that, the fuel pump comes on when sensing a signal from the rotating distributor. so you will want to check out where the signal from the dist goes, and what it goes to to kick the fuel pump on Link to comment Share on other sites More sharing options...
Skip Posted December 4, 2003 Share Posted December 4, 2003 Well Donald it is not quite as simple as vols (what are they, small rodents?) and dists If you follow this link http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=4322&highlight=fuel+pump You will see, we all can learn something from doing some searching and reading. The seatbelts of all things?? Link to comment Share on other sites More sharing options...
MilesFox Posted December 4, 2003 Share Posted December 4, 2003 i am posting from what i know and my experiences more than from what i read off the board. Link to comment Share on other sites More sharing options...
Snowman Posted December 9, 2003 Author Share Posted December 9, 2003 Now I'm REALLY confused. Today I put the pump back on, and just for s***s and giggles turned the key, and it started right up! Runs fine ever since. I'm gonna go check the fuel pump relay, and test the voltage at the pump again to try to figure out what was going wrong. Maybe Alice was just not happy with me last week for some reason. Link to comment Share on other sites More sharing options...
