Scott in Bellingham Posted July 30, 2007 Share Posted July 30, 2007 Im interested in putting a Carb on a EJ thats in my EA wagon, also a distributer , what have you guys done and what works, lets see some pictures, thanks Scott Link to comment Share on other sites More sharing options...
86BRATMAN Posted July 30, 2007 Share Posted July 30, 2007 Hey Scott, Here is a thread on the subject. With a good link to the aeromotive world. http://www.ultimatesubaru.org/forum/showthread.php?t=35174&highlight=ej22+distributor Shannon Link to comment Share on other sites More sharing options...
75subie Posted July 31, 2007 Share Posted July 31, 2007 could i ask why? just curious. its funny tho, theres people with their carbed ea81s switching to spfi, and now people withs ejs wanting to go back a step to carbs. Link to comment Share on other sites More sharing options...
bratsrus1 Posted July 31, 2007 Share Posted July 31, 2007 Hey Scott This is Jerry, the dissy is from a 82 escort and get the coil also. That set up has 3 wires one gose to the hot side of the coil another gose to the ground side of the coil and the last one gose to the start side of the starter. I have the drawing of it and for the carb didn't you see that intake i had at the show. You don't have to weld a 4 barrel adapture on it you can weld a 2 barrel plate on it or build your own intake. If you want a copy of the wiring for the dissy i can mail it to you. Let me know Thanks Jerry Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 31, 2007 Author Share Posted July 31, 2007 Hey Scott This is Jerry, the dissy is from a 82 escort and get the coil also. That set up has 3 wires one gose to the hot side of the coil another gose to the ground side of the coil and the last one gose to the start side of the starter. I have the drawing of it and for the carb didn't you see that intake i had at the show. You don't have to weld a 4 barrel adapture on it you can weld a 2 barrel plate on it or build your own intake. If you want a copy of the wiring for the dissy i can mail it to you. Let me know Thanks Jerry so its a 82, will any other years work for the disty? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 31, 2007 Author Share Posted July 31, 2007 could i ask why? just curious. . I have a EA wagon , not wired for the EJ its a offroad rig, want it simple and able to be drowned in the water and still go, Link to comment Share on other sites More sharing options...
Matty B Posted July 31, 2007 Share Posted July 31, 2007 Go for it Scott...search jet boats and Subarus (usually in NZ) EJ20 Weberred and disty fed. No room for failure when its a single engined boat. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 31, 2007 Author Share Posted July 31, 2007 Go for it Scott...search jet boats and Subarus (usually in NZ) EJ20 Weberred and disty fed. No room for failure when its a single engined boat. what sized carbs are those? what size type would be good for lowend tourque?? , I like the twin carb idea, Link to comment Share on other sites More sharing options...
pisces_0 Posted July 31, 2007 Share Posted July 31, 2007 I have no intention of ever removing the fuel injection system from my EJ22, but this carbureted business has piqued my interest from a purely mechanical point of view. Hey Scott This is Jerry, the dissy is from a 82 escort and get the coil also. I'm also assuming you mean an '82 Ford Escort w/ 1.6L engine. Here's a pic of the distributor: Maybe I'm missing something glaringly obvious, but how does it mount to the engine and what drives the distributor? Link to comment Share on other sites More sharing options...
pisces_0 Posted July 31, 2007 Share Posted July 31, 2007 I think I see the disty now. Is that it on the rear of the right side (passenger's side) head? Doh, I knew it'd be something simple like that! Link to comment Share on other sites More sharing options...
bratsrus1 Posted July 31, 2007 Share Posted July 31, 2007 Hey Everybody This is Jerry, thats the dissy and it mounts on the right head in the back. There is a plug on the head that you remove and the dissy bolts to it. The cam drives the dissy. If you use the stock intake and install soft plugs in the injectors holes that solves that problem then mount a carb adapture on the manifold you have the set up. Thanks Jerry Link to comment Share on other sites More sharing options...
monstaru Posted August 1, 2007 Share Posted August 1, 2007 as of about 2 hours ago,i have a running ej22 with a weber 32/36 on it.a 1982 escort disty,with a mechanical homemade advance,on an raf custom intake.runs rich as ************ right now,going to retard it this afternoon.i am currently trying to download the video of it running from my phone. cheers brian..... CAPITALIZED ************ING!!!!!!! WOOOOOOOOOTTTTTTT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
crazy D Posted August 2, 2007 Share Posted August 2, 2007 Hey Everybody This is Jerry, thats the dissy and it mounts on the right head in the back. There is a plug on the head that you remove and the dissy bolts to it. The cam drives the dissy. If you use the stock intake and install soft plugs in the injectors holes that solves that problem then mount a carb adapture on the manifold you have the set up. Thanks Jerry interesting....have you got your set up to run jerry? the subaru kid -Dalton Link to comment Share on other sites More sharing options...
bratsrus1 Posted August 2, 2007 Share Posted August 2, 2007 Hi D This is Jerry, not yet i am building an engine stand so i can run it out of the car so i can set the timing. When everything is all set then i will install it in my hatchbrat. This will happen soon real soon. Thanks Jerry Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 22, 2007 Author Share Posted August 22, 2007 OK Im ready to do it , need 2 82 Escort distys as Rollies getting one also, will be casting a weber adapter and weld it to the stock EJ manifold, this will be something I will offer is somebody wants one, Link to comment Share on other sites More sharing options...
Matty B Posted August 23, 2007 Share Posted August 23, 2007 Bloody good plan Scott. Best of luck with them. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 17, 2007 Author Share Posted October 17, 2007 OK Im ready to do it , need 2 82 Escort distys as Rollies getting one also, will be casting a weber adapter and weld it to the stock EJ manifold, this will be something I will offer is somebody wants one, still need a disty just a update on the EJ carb Adapter, have cast one, making pattern improvements and this will be a bolt on Item using the coil pack threaded bosses :cool: Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 18, 2007 Share Posted October 18, 2007 Going to the junkyard this weekend scott. Im sure I can find a '82 Escort. I'll report back to you if I find something. -Brian Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 18, 2007 Author Share Posted October 18, 2007 Going to the junkyard this weekend scott. Im sure I can find a '82 Escort. I'll report back to you if I find something. -Brian I'll buy it thanks, also need coil and wires Scott Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 18, 2007 Share Posted October 18, 2007 Bored at work, I used my Napa Prolink account to look up Distributors for the '82 Escort. They list two. One with an attatched module, and one that has a detatched module. Napa Links: Attatched Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NRD&PartNumber=482493&Description=Distributor+(Electronic+w%2fo+Module)+-+Remfd Detatched Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NRD&PartNumber=482492&Description=Distributor+(Electronic+w%2fo+Module)+-+Remfd Module for distributor attached model: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=MPE&PartNumber=TP30SB&Description=Ignition+Control+Module Fender Mounted Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=MPE&PartNumber=TP40SB&Description=Ignition+Control+Module I think i'll look up coils too. -Brian Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 18, 2007 Share Posted October 18, 2007 Here are the coils. This is the coil for the distributor mounted module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=IC24&Description=Ignition+Coil Here is the connector: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=ICC1&Description=Ignition+Coil+Connector They list a coil for a Fender Mounted Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=IC21&Description=Ignition+Coil However, for this application I believe you would want the distributor mounted module. Correct me if im wrong? Prices like these make it seem better to buy new (reman) than trusting a junkyard part. -Brian Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 18, 2007 Author Share Posted October 18, 2007 Here are the coils. This is the coil for the distributor mounted module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=IC24&Description=Ignition+Coil Here is the connector: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=ICC1&Description=Ignition+Coil+Connector They list a coil for a Fender Mounted Module: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=ECH&PartNumber=IC21&Description=Ignition+Coil However, for this application I believe you would want the distributor mounted module. Correct me if im wrong? Prices like these make it seem better to buy new (reman) than trusting a junkyard part. -Brian disty mt module ideal good stuff, now if a parts car is a good risk getting the complete system is preferable , cut the wire so you get the plugs get disty with all the wires with sparkplug wires and the coil wire coil and plugs and wires on the coil and coil mt. that way I would have everything I need and wont have to peice together things thanks Scott Link to comment Share on other sites More sharing options...
monstaru Posted October 18, 2007 Share Posted October 18, 2007 do you just wanna buy my stuff?pm if so........cheers, brian disty mt module ideal good stuff, now if a parts car is a good risk getting the complete system is preferable , cut the wire so you get the plugs get disty with all the wires with sparkplug wires and the coil wire coil and plugs and wires on the coil and coil mt. that way I would have everything I need and wont have to peice together things thanks Scott Link to comment Share on other sites More sharing options...
