Uberoo Posted July 31, 2007 Share Posted July 31, 2007 Is it possible to change the headgaskets on an EJ22 that is currently sitting in a 1987 GL wagon without pulling the motor?On an EA82 it was doable but difficult because it had studs.Does the Ej22 have these studs?Or should I just pull the motor? Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 1, 2007 Share Posted August 1, 2007 Ej's have bolts like an ea82. And are narrower by a touch. You should have no trouble changing the hg's in car. Link to comment Share on other sites More sharing options...
Uberoo Posted August 1, 2007 Author Share Posted August 1, 2007 Can I actally clean the surfaces enough in the car so the headgaskets don't fail aqain ever?The heads will be clean(I'll have them flattened) but can I get enough off the block so it doesn't blow a headgasket for another 100K.Ive changed a headgasket in a EA81 and even had the heads flattened and it failed again less than 100 miles latter.So Im leary about doing it in car.. Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 1, 2007 Share Posted August 1, 2007 All you need to really worry about is getting all the gasket material removed from the block itself. The heads should not be smooth, so have them check ed and resurfaced if needed. Maybe even take some medium grit sandpaper(200-400 grit) and lightly rough up the surface of the block. O/T, did you follow the retorque sequence on the ea81 motor? I've never seen one blow a h/g twice in my life if it's done correctly. Link to comment Share on other sites More sharing options...
Uberoo Posted August 1, 2007 Author Share Posted August 1, 2007 yes I followed the retorque correctly .it just seems there was a bit of gasket near the studs that I couldnt get... Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 1, 2007 Share Posted August 1, 2007 You shouldn't have that issue with the ej. But if it makes you feel more comfortable with your work, go ahead and pull the motor. Piece of mind is priceless. Link to comment Share on other sites More sharing options...
