Front axle replacemet
Some things we have covered a great many times. Here's a great thread about that, and if you try out the search function up at the top of the page, you'll find other threads that cover this procedure too. I'm sure everything you need is to be found in them somwhere. :eek:
http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=2576&highlight=axle+removal
the most important part is removing the axle without boogering up the htreads/
you want the whole strut assembly to pull away enough for the axle to slide off the tranny end(after the pin is removed)
then you want to pound the axle thru the knuckle till it pops out.
thread teh castle nut on BACKWARD intil its flush with the axle stub. use a 3 poind hammer and a block of wood to start pounsing it thru. it has to pound thru 2 bearings, pouns it thru so far and remove the nut. then use a pipe, or hold the round end of a ball-peene hammer against the axle, pound on it with the fat hammer.
to reinstall the axle, but it on the tranny end first, then slip it thru by hand what you can, and tap around the knuckle to persuade the axle thru.
once the axle is thru enough, you can put on the rotor and then the nut, and use the nut to draw it thru. you will have to use the nut with no washers to catch the first thread, draw it thru, then remove the nut, put on the washers, then draw it all the way thru and torque it down
people will tell of several ways to pop the ball jount, take off the lower control arm, etc. but the main objective it to be able to pull the strut assembly away from the car enough to slide the axle off the tranny, and enough to let it dangle and pop thru without the car being in its way
Thanks, whit those instructions it was easy to do it. but now i have another problem, when i took it out for a test drive, something started ticking when on the gas, as soon as i let off it stopped, i went back through everything i had done, i couldnt find anything, so i took it out again, and it was doing it again, the faster went the faster it ticked. I was thinking this is the inboard joint. What do you guys think?
