kingbobdole Posted August 1, 2007 Share Posted August 1, 2007 While removing the intake on my 89 XT-6 to test fit some things I discovered this: The trans to firewall mount is not only bent to a 90 degree angle, but the mount itself has been snapped right off the tranny! I have no idea how or when this happened... unless it was that time I lost a bolt out of the tranny crossmember and the tranny fell a little bit... can't recall hitting the tranny on anything... :-/ I'll have to check my spares tomorrow and see if I have another. Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 1, 2007 Share Posted August 1, 2007 I bet it was due to the pressure from that spring. Wheres BGD when you need him;) Quote Link to comment Share on other sites More sharing options...
bratsrus1 Posted August 1, 2007 Share Posted August 1, 2007 Hi This is Jerry, i bet it is when your right foot tryed to touch the pistons or should i say it's called horse power baby:grin: Thanks Jerry Quote Link to comment Share on other sites More sharing options...
daeron Posted August 1, 2007 Share Posted August 1, 2007 Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 1, 2007 Share Posted August 1, 2007 holy hell.... Quote Link to comment Share on other sites More sharing options...
subynut Posted August 1, 2007 Share Posted August 1, 2007 Ouch. Quote Link to comment Share on other sites More sharing options...
Durania Posted August 1, 2007 Share Posted August 1, 2007 Slow Dragon Poison. Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 1, 2007 Share Posted August 1, 2007 Slow Dragon Poison. It must be reeeeaaal slow. He didnt make it to the Dragon this year:-p Quote Link to comment Share on other sites More sharing options...
ShawnW Posted August 1, 2007 Share Posted August 1, 2007 That is so hot. The replacement part should definately be painted yellow. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 1, 2007 Share Posted August 1, 2007 That is so hot. The replacement part should definately be painted yellow. Good for 25 Hp at his rear wheels:lol: I know his car is fwd... Quote Link to comment Share on other sites More sharing options...
TomRhere Posted August 1, 2007 Share Posted August 1, 2007 Think I would be looking at condition of the front motor mount. Missing bolt from tranny X-member may have caused it, but the front mount should've held engine from pitching that far.... Just my .02 Quote Link to comment Share on other sites More sharing options...
nipper Posted August 1, 2007 Share Posted August 1, 2007 There always has to be one problem child Check all the mounts. Thats a pretty big bend for a tranny that dropped "a little" . i hear the grand canyon is a little hole in the ground :-p nipper Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted August 1, 2007 Share Posted August 1, 2007 Good for 25 Hp at his rear wheels:lol: I know his car is fwd... no, it's good for 30 HP at the center differential in neutral, but only if he has a third generation thermo confibrulator. Quote Link to comment Share on other sites More sharing options...
nipper Posted August 1, 2007 Share Posted August 1, 2007 no, it's good for 30 HP at the center differential in neutral, but only if he has a third generation thermo confibrulator. Doesnt that require the muffler bearing upgrade? nipper Quote Link to comment Share on other sites More sharing options...
Bucky92 Posted August 1, 2007 Share Posted August 1, 2007 You know Phil...if you would have come to the Dragon Meet..this would have never happened..Cheesewedge is telling you its upset that it couldnt be around more of its own kind...yellow Alcyones! Quote Link to comment Share on other sites More sharing options...
daeron Posted August 2, 2007 Share Posted August 2, 2007 Doesnt that require the muffler bearing upgrade? nipper No, but if he doesnt have fresh blinker fluid he just might trash the running light/turn signal journals. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 2, 2007 Share Posted August 2, 2007 whoo, last time I saw one that bad, my hoses had ripped of the radiator. That was because of a disagreement between the oil pan and a rock. Done any rollback clutchdumps? Quote Link to comment Share on other sites More sharing options...
