lhrocker Posted August 3, 2007 Share Posted August 3, 2007 Has anyone used the 1 to 3 12 volt adapters in their Subies? Are there any issues or hazards? I would just need to run a GPS and iPod or XM radio. Thanx in advance. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted August 3, 2007 Share Posted August 3, 2007 I've run a 1 to 2 adapter. There's no risk of overloading the vehicle's outlet since that is fused. The three devices you mentioned are not power hogs anyway so it shouldn't be an issue. Also there is a Subaru accessory you can get that I think gives you two more outlets. I think maybe nipper has one installed? It kind of mounts where the ashtray is I think Quote Link to comment Share on other sites More sharing options...
nipper Posted August 3, 2007 Share Posted August 3, 2007 I have the factory kit that replaces the ashtray with two more (higher amp) outlets. One of the online suppliers will have it. nipper Quote Link to comment Share on other sites More sharing options...
rverdoold Posted August 4, 2007 Share Posted August 4, 2007 I was thinking the same. Want to put my GPS on there and a small coolbox (75W). I thought it holds a 10A fuse so that around 6.25A for the coolbox and 2.4A for the GPS (at max output). Is it not bad to continiuous have about 8 to 9 amp load on the wiring? I also have a penlite charter but that takes 5A so either GPS + charger or GPS + coolbox i guess. Quote Link to comment Share on other sites More sharing options...
nipper Posted August 4, 2007 Share Posted August 4, 2007 The kit comes with a factory harness, a relay, and a heavy fused line. It was built by subaru to literally clip right into the car. Your not going to hurt anything. nipper Quote Link to comment Share on other sites More sharing options...
starkiller Posted August 4, 2007 Share Posted August 4, 2007 nipper you happen to have a part number or something? tried the subie parts sites i know and nothing comes up for it.. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted August 5, 2007 Share Posted August 5, 2007 H6710AE000 Legacy 1995-2004, Outback 1996-2004, DUAL POWER OUTLET KIT W/INSTRUCTIONS The pic shows this one mounts in the coin cup holder near the parking brake handle. Quote Link to comment Share on other sites More sharing options...
nipper Posted August 5, 2007 Share Posted August 5, 2007 or http://www.ultimatesubaru.org/photos/showphoto.php?photo=12899&cat=918 which sooby are we talking about nipper Quote Link to comment Share on other sites More sharing options...
starkiller Posted August 5, 2007 Share Posted August 5, 2007 93 legacy wagn Quote Link to comment Share on other sites More sharing options...
Guest jclay Posted May 19, 2011 Share Posted May 19, 2011 would this product be constant "hot" or ignition dependant? thanks! Quote Link to comment Share on other sites More sharing options...
