I've run a 1 to 2 adapter. There's no risk of overloading the vehicle's outlet since that is fused. The three devices you mentioned are not power hogs anyway so it shouldn't be an issue.
Also there is a Subaru accessory you can get that I think gives you two more outlets. I think maybe nipper has one installed? It kind of mounts where the ashtray is I think
I was thinking the same.
Want to put my GPS on there and a small coolbox (75W). I thought it holds a 10A fuse so that around 6.25A for the coolbox and 2.4A for the GPS (at max output). Is it not bad to continiuous have about 8 to 9 amp load on the wiring?
I also have a penlite charter but that takes 5A so either GPS + charger or GPS + coolbox i guess.
  • 3 years later...
