SubaruWagon87 Posted August 3, 2007 Share Posted August 3, 2007 Can I replace the front axles in my 83 dl 4wd with some from an 82 gl fwd? Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 3, 2007 Share Posted August 3, 2007 You sure can. There is just a slight difference in the axles, but nothing to worry. Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted August 4, 2007 Author Share Posted August 4, 2007 What's the difference? Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted August 4, 2007 Share Posted August 4, 2007 What's the difference? The actual shaft diameters are different. However, the cup and stub are the same, and they're the same length. Quote Link to comment Share on other sites More sharing options...
pinksock Posted August 4, 2007 Share Posted August 4, 2007 Yes I can be done! thats what my buddy is running on his. Tony~ Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 4, 2007 Share Posted August 4, 2007 This is a little off the point, but Ive found out that on the ea82s the 2wd have differents splines and and don't fit on a 4wd, cuz I tried replacing mine with a pair from a 2wd, but they didn't work. Anyways, just wanted to mention that. -Bill Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted August 4, 2007 Author Share Posted August 4, 2007 Thanks for the help guys. I've yet to swap them, but hopefully it'll get done sunday. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 4, 2007 Share Posted August 4, 2007 This is a little off the point, but Ive found out that on the ea82s the 2wd have differents splines and and don't fit on a 4wd, cuz I tried replacing mine with a pair from a 2wd, but they didn't work. Anyways, just wanted to mention that.-Bill No way man. Something else was up there. All non-turbo EA82s* use 23 spline axles. Now there is a difference between 2wd and 4wd joints themselves, with the later being larger and tougher. But really in the end any 23 spline EA82 axle will fit on the front end. The only EA82 cars with different spline counts where the 2wd MT Turbos and all 4wd Turbos* *XTs are different. 85-87 Turbo 2wd Auto(3at), and all Non-turbo= 23 spline 85-87 Turbo 2wd MT, and all Turbo 4wd = 25 spline 88-91 4 Cyl MT 2wd and 4wd =23 spline 88-91 4 Cyl Auto(4EAT) and all XT6 = 25 spline Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted August 5, 2007 Share Posted August 5, 2007 85-87 Turbo 2wd Auto(3at), and all Non-turbo= 23 spline85-87 Turbo 2wd MT, and all Turbo 4wd = 25 spline 88-91 4 Cyl MT 2wd and 4wd =23 spline 88-91 4 Cyl Auto(4EAT) and all XT6 = 25 spline If you insist on making an all inclusive list, also note that any 4WD 3AT Turbo still has the 23 splines. Quote Link to comment Share on other sites More sharing options...
