85glsw Posted August 3, 2007 Share Posted August 3, 2007 Would an '88 DL 4wd SW front strut fit an '85 4wd GL? Mine has the strut lifters. The '88 doesn't. To complicate matters, I only want to replace one. Perhaps I should have started by saying that the reason I am considering replacing it, is because the bearing on the strut tower crown is going bad and makes all kinds of noise (probably because the rubber boot cracked and water gets in there. The boot on the CV joint is completely off, so I have to get under there anyway. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 4, 2007 Share Posted August 4, 2007 The struts should interchange, as long as the 85 is an ea82 Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 4, 2007 Share Posted August 4, 2007 The struts should interchange, as long as the 85 is an ea82 What he said... Quote Link to comment Share on other sites More sharing options...
