ktsubaru Posted August 4, 2007 Share Posted August 4, 2007 Since some people are interested in Dual Range Transmission, I did some research on it and I want to know if I understand the thing right, In Sep 1994, Impreza C model ( whenever they change the model slightly, Subaru Japan changes the model code such as GC8A, GC8B, GC8C, over there) they installed "Double Cone Synchronized Gear" on the second gear. On WRX type RA in JDM, they installed that gear on the third gear In Sep 1996, they installed the same one on the third gear in all the JDM turbo models (model Code GC8D) Let me know if I'm right or wrong in understanding what you guys mean by "Dual Range Transmission":) Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 4, 2007 Share Posted August 4, 2007 Wrong. Dual range 4wd. Remains front wheel drive untill you pull a lever. It has selectable 4wd hi and 4wd low ranges. You will have better luck sourcing these through the legacy lineup. Think of what the older subaru's have. These guys aren't wanting these for speed or power holding capability. They want them for the off-road. Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 4, 2007 Share Posted August 4, 2007 Here is a link from an austrailin board. It has pics of the shifters and the car its it. http://www.ausubaru.com/forum/showthread.php?t=6832&highlight=dual+range Link to comment Share on other sites More sharing options...
ktsubaru Posted August 4, 2007 Author Share Posted August 4, 2007 Here is a link from an austrailin board. It has pics of the shifters and the car its it. http://www.ausubaru.com/forum/showthread.php?t=6832&highlight=dual+range ic, i think what the japanese guys call "part time AWD" are the ones they want. ( I know it sounds wrong....) Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 4, 2007 Share Posted August 4, 2007 If thats what they call it then it sound right by their terms. Been doing some more reading on the site I linked up. Either I'm wrong about them being fwd normal, or some aussie terminology confuses me. But either way, it sounds like you've got the idea of what these guys want now. Link to comment Share on other sites More sharing options...
ktsubaru Posted August 4, 2007 Author Share Posted August 4, 2007 If thats what they call it then it sound right by their terms. Been doing some more reading on the site I linked up. Either I'm wrong about them being fwd normal, or some aussie terminology confuses me. But either way, it sounds like you've got the idea of what these guys want now. Okay, so I will check with exporters in Japan if they can find 'em. what I saw in Japan for Legacys are lots of full time AWDs.... hope I can find them. Link to comment Share on other sites More sharing options...
mikeshoup Posted August 5, 2007 Share Posted August 5, 2007 Sure those are part time 4WD? I swore I read that they were Full Time 4WD. Too bad the picture of the sticker is unreadable. Link to comment Share on other sites More sharing options...
ezapar Posted August 5, 2007 Share Posted August 5, 2007 Okay, so I will check with exporters in Japan if they can find 'em.what I saw in Japan for Legacys are lots of full time AWDs.... hope I can find them. You would be the absolute HERO around here if you can pull it off! Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 5, 2007 Share Posted August 5, 2007 Sure those are part time 4WD? I swore I read that they were Full Time 4WD. Too bad the picture of the sticker is unreadable. I'm not sure on those either. I read something that said one thing and then stuff saying the other. Link to comment Share on other sites More sharing options...
Spiffy Posted August 5, 2007 Share Posted August 5, 2007 I think it's called Dual-Range AWD everywhere... it can be identified by the extra dual-range lever near the parking break... probably only available with the 5-speed (5MT)... you can see it in the interior shots here... an article from the UK talks about one in the 2007 model... and here's a good pic from the italian subaru site... I have no idea why they didn't import these into the US as everybody seems to want them... --Spiffy Link to comment Share on other sites More sharing options...
ktsubaru Posted August 7, 2007 Author Share Posted August 7, 2007 Well, this vehicle is 1986 model and the car needs to be disassembled in order to make it legal to import to USA, however, it is dual-range AWD and I guess the car has some way some of u guys can make good use out of it, such as engines etc..... http://auction.goo-net.com/item/show/22485 Link to comment Share on other sites More sharing options...
Spiffy Posted August 7, 2007 Share Posted August 7, 2007 that's an EA series vehicle... the dual-range AWD that the US didn't get is on the EJ series vehicles... mostly people want to mate the EJ22 and EJ25 engines to a newer generation transmission... in the US they got rid of the dual-range with the EA series (loyale) and none of the newer models (1990+ legacy/impreza) have dual-range... --Spiffy Well, this vehicle is 1986 model and the car needs to be disassembled in order to make it legal to import to USA, however, it is dual-range AWD and I guess the car has some way some of u guys can make good use out of it, such as engines etc..... http://auction.goo-net.com/item/show/22485 Link to comment Share on other sites More sharing options...
Numbchux Posted August 7, 2007 Share Posted August 7, 2007 the EJ D/Rs were full-time. they have the same center diff as any other EJ AWD subaru, but have a low range gearset on the input shaft before any of the other gears, and right above the front diff. on EA cars, it has a mechanical linkage that pushes the lever to engage it on EJ ones, it's a vacuum solenoid. I believe they're most commonly found on the Liberty GX Link to comment Share on other sites More sharing options...
ktsubaru Posted August 8, 2007 Author Share Posted August 8, 2007 I got info from Subaru dealership in Japan: 1.Dual Range Transmission: Available on JDM BH model Legacy "Lancaster" and JDM forester SF5 model. Both in 5spd only. Some export models (export from Japan) of Legacy BP/BL have dual range transmission. Link to comment Share on other sites More sharing options...
Numbchux Posted August 8, 2007 Share Posted August 8, 2007 Some export models (export from Japan) of Legacy BP/BL have dual range transmission. never heard of a BP/BL....maybe the Liberty GX that I was referring to? EDIT: nevermind, BP/BL is the '05+ legacy and your link/img didn't work. the ones we're talking about were in early '90s cars. pretty sure just BC/BJ/BFs. EDIT AGAIN: according to Wikipedia, just the European and British Wagons got the D/R tranny....but I know they got them in Australia too. Link to comment Share on other sites More sharing options...
ktsubaru Posted August 8, 2007 Author Share Posted August 8, 2007 never heard of a BP/BL....maybe the Liberty GX that I was referring to? EDIT: nevermind, BP/BL is the '05+ legacy and your link/img didn't work. the ones we're talking about were in early '90s cars. pretty sure just BC/BJ/BFs. EDIT AGAIN: according to Wikipedia, just the European and British Wagons got the D/R tranny....but I know they got them in Australia too. I'm able to get hold of Subaru Export Dept in Japan and I am discussing about dual range transimission. Give me a few days to give u guys the info such as availability, price, etc... Link to comment Share on other sites More sharing options...
ezapar Posted August 8, 2007 Share Posted August 8, 2007 I'm able to get hold of Subaru Export Dept in Japan and I am discussing about dual range transimission. Give me a few days to give u guys the info such as availability, price, etc... YAY! I'll be waiting. Link to comment Share on other sites More sharing options...
idosubaru Posted August 9, 2007 Share Posted August 9, 2007 not a transmission guy, but is it possible to also source the parts for the dual range transmission? guess it's a long shot, but could you convert a single range to a dual range? the EA82 guts all swap, figure the EJ stuff does too? Link to comment Share on other sites More sharing options...
ktsubaru Posted August 11, 2007 Author Share Posted August 11, 2007 I just got an E-mail from Subaru Japan export team, and they can supply dual range transmission to here I’m modifying my post here. I think it's almost impossible to find out the parts number of that transmissions. Instead, I bet Subaru Japan can search for it if we can give them in what vehiles ( year and model) do they have dual range transmissons, then they can look up the parts info. Link to comment Share on other sites More sharing options...
awlllwa Posted August 19, 2007 Share Posted August 19, 2007 soooo, dose anyone really want this transmission. We cant look up prices and availability if no one gives us anything to look up. :-p Link to comment Share on other sites More sharing options...
Numbchux Posted August 20, 2007 Share Posted August 20, 2007 soooo, dose anyone really want this transmission. We cant look up prices and availability if no one gives us anything to look up. :-p as if a part number was that easy to get :-\ I'm looking.... Link to comment Share on other sites More sharing options...
awlllwa Posted August 21, 2007 Share Posted August 21, 2007 as if a part number was that easy to get :-\ I'm looking.... we don't even really need the part number, if you can give us specific information on the original vehicle this transmission was installed in or some leads on helping us find the part numbers then we can get closer to a quote. Link to comment Share on other sites More sharing options...
Numbchux Posted August 21, 2007 Share Posted August 21, 2007 we don't even really need the part number, if you can give us specific information on the original vehicle this transmission was installed in or some leads on helping us find the part numbers then we can get closer to a quote. '90-'94 Liberty GXs, like I said above. possibly only available in European, British, and Australian markets (not japanese...). Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 24, 2007 Share Posted August 24, 2007 Nearly every subaru I saw in England had a dual range AWD transmission. It is normal AWD, with a viscous center differential, but it has a hi/lo range selector lever next to the handbrake. It's a setup that's been used from 1990-at least 2005 was the newest impresa wagon I saw with it. The ones out of the 1.8 turbo EA18 cars are worthless, we've already goth them here. Link to comment Share on other sites More sharing options...
ktsubaru Posted August 25, 2007 Author Share Posted August 25, 2007 i got a reply from Subaru Japan. JDM Subaru has dual range transmission on Subaru Forester Yr96 to 02 models. Legacys - Subaru export dept doesn't release the export items non officially, so it is hard for them to release those Liberty parts to individuals. If Forester dual range transmission fits into your vehicles, I will ask the quote to subaru. Link to comment Share on other sites More sharing options...
