Muffler Question STUPID!
Just got a new muffler for the Buggy.
One end, of the muffler, is off-set the other is centered.
It fits better one direction.
The problem is the <A-B> stamped on the muffler will be reversed <B-A>. B at the front A at the rear if I install it in the best fitting direction.
Is this a problem?
Anyone know the <A-B> stamp? I don't know mufflers!:cornfuzz:
Thanks,
Glenn
82 Hatch, well it use to be.........
01 Forester, still is..............
Its a universal muffler. I believe you can run it either way. I think depending on which direction you install it there will be a different back pressure. But I don't think it will matter to much. Install it one way and maybe drive it a couple of days and then flip it to see if it is better. it won't hurt anything.
--GoatBoy--
From what you guys are telling me it seems as though it is a "universal" type. Box says nothing about direction of flow.
The flow diagram looks like this <A-----B> That might mean it can flow either way?
Mudrat thought it could go either way too!
I'm hookin it up!
Thanks for the feed back
Glenn
82 Summer, (Subaru Hummer) soon to have an exhaust system.
01 Forester, already has exhaust system!
