oliveim Posted August 5, 2007 Share Posted August 5, 2007 I am looking at purchasing a 99 legacy outback with about 93,000 miles on it. The owner says that the car overheated but stopped when he removed the thermostate. He says that he hasn't had a chance to look at the problem but he thinks it may be the headgasket. Anyone have any ideas. Thanks Link to comment Share on other sites More sharing options...
porcupine73 Posted August 5, 2007 Share Posted August 5, 2007 Well it is quite possible it is the head gaskets. It could be other things, such as if the thermostat were not opening properly, but that would be the phase I engine so HG issues are not out of the question. Link to comment Share on other sites More sharing options...
Cougar Posted August 5, 2007 Share Posted August 5, 2007 It very well could be a gasket problem but it may be the radiator also. I would get a block check done to see if that is the case. If the temp rises real fast then I would suspect the gaskets. You may be able to get the car at a discounted price. Link to comment Share on other sites More sharing options...
nipper Posted August 5, 2007 Share Posted August 5, 2007 At that mileage it will not be the radiator (unless it leaks). There are three possabilities. One is a bad Tstat. Another is a bad radiator cap, the third is a HG. Is this a dual cam or single cam engine. Id its dual, internal HG, if its single, the HG usually fails with an external leak and wont cause overheating. Look at the condition of the fluid in the overflow. Start the car with the Rad cap off and watch for bubbles. With the T stat gone this would be an easy and quick test. See if the car has heat. Ask the seller if he had any work done to the car recently. How much is he asking? nipper Link to comment Share on other sites More sharing options...
oliveim Posted August 6, 2007 Author Share Posted August 6, 2007 He's asking $6900. The car is a limited edition and he says he changed the thermostat but hadn't done anything else to determine the problem. Link to comment Share on other sites More sharing options...
uniberp Posted August 6, 2007 Share Posted August 6, 2007 He's asking $6900. The car is a limited edition and he says he changed the thermostat but hadn't done anything else to determine the problem. 99Legob is DOHC. Probably Headgasket. If the owner knew how to remove the thermostat he knew more, that the HG was gone. 6900 is way out of the range. Offer him 3500 if everything else is perfect. Test drive it and leave a hidden note for the potential new owner that they need major engine work and were probably ripped off if they paid anything close to to KBB. Link to comment Share on other sites More sharing options...
rweddy Posted August 6, 2007 Share Posted August 6, 2007 99Legob is DOHC. Probably Headgasket. If the owner knew how to remove the thermostat he knew more, that the HG was gone. 6900 is way out of the range. Offer him 3500 if everything else is perfect. Test drive it and leave a hidden note for the potential new owner that they need major engine work and were probably ripped off if they paid anything close to to KBB. I would agree, that is way too high. The seller knows the HG is blow I bet and looking to dump the car on an unsuspecting buyer. Link to comment Share on other sites More sharing options...
nipper Posted August 6, 2007 Share Posted August 6, 2007 yup way too much money. nipper Link to comment Share on other sites More sharing options...
oliveim Posted August 6, 2007 Author Share Posted August 6, 2007 Thanks everyone for the response, I suspected head gasket but wasn't sure. Link to comment Share on other sites More sharing options...
