sgregory Posted August 5, 2007 Share Posted August 5, 2007 Hello all, I have a 93 impreza 1.8, starts great first thing runs and idles well, but then after it has been driven a while, when I go to restart it just cranks and cranks, have to pump the gas some to get it started. Once it is started again it runs fine. Put in new batt. just for ample crank, replaced fuel filter, plugs, wires, ran two bottles of injector cleaner through, and it is still giving me problems after its warmed up. The problem started about 3 weeks ago and has just become more frequent. Any ideas as to what this might be would be greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
nipper Posted August 5, 2007 Share Posted August 5, 2007 Sounds like a bad TPS or ecu engine temp sensor. When the car gets hot either one may have a open or a dead spot in them. bipper Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted August 5, 2007 Share Posted August 5, 2007 Possible causes could include cam and/or crank position sensors or engine coolant temp sensor. Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 5, 2007 Share Posted August 5, 2007 It sounds like you are leaning towards a fuel problem which it very well could be. Have you checked the ignition to see if the plugs are getting spark while this trouble is occuring? Quote Link to comment Share on other sites More sharing options...
nipper Posted August 5, 2007 Share Posted August 5, 2007 YOu may have to find a chicken to slaughter to pull the codes from the ECU. I forget the ritual for a obdI but it involves a chicken, some candles, and i think an eye of newt. Do a search here, someplace or someone will tell you how to check the codes. Thats a good place to start. Its going to be an intermittent failure whic can be a pita. The crank sesnor controls spark, the cam controls fuel. nipper Quote Link to comment Share on other sites More sharing options...
sgregory Posted August 5, 2007 Author Share Posted August 5, 2007 I will see if I can figure out how to get the codes. It's such an intermitten problem it's going to be fun to track down. Thanks for a starting point to look for the problem. Quote Link to comment Share on other sites More sharing options...
beataru Posted August 6, 2007 Share Posted August 6, 2007 It does sound like a fuel problem, I remember last year at my vocational tech school (EVIT) my instructor had a guy come in with a GMC Sierra and he said that when He comes back to it after it has sit for like 15 mins or something, that it takes just a little bit longer for it to start, my instuctor said it was the checkvalve on the regulator and he was right, Im not familier with the 1.8s but this toatally sounds like fuel pressure is bleeding... Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 6, 2007 Share Posted August 6, 2007 Go to the Bat Automotive web site and then select the trouble codes for Subaru. Follow the help given there on the codes and location of the ECU. Quote Link to comment Share on other sites More sharing options...
sgregory Posted August 6, 2007 Author Share Posted August 6, 2007 Go to the Bat Automotive web site and then select the trouble codes for Subaru. Follow the help given there on the codes and location of the ECU. I will give that a try. Thanks Quote Link to comment Share on other sites More sharing options...
