floater Posted August 6, 2007 Share Posted August 6, 2007 I can't get my rear differential plugs out. I don't want to spend any more time on it. Going to take it in. What should I expect to pay for a drain and fill? Link to comment Share on other sites More sharing options...
svxpert Posted August 6, 2007 Share Posted August 6, 2007 I can't get my rear differential plugs out. I don't want to spend any more time on it. Going to take it in. What should I expect to pay for a drain and fill? what are you using to get them out? being a CA car, shouldn't be too much rust/corrosion. Link to comment Share on other sites More sharing options...
Olnick Posted August 6, 2007 Share Posted August 6, 2007 I can't get my rear differential plugs out. Once upon a time mine were super tight too. Couldn't break them loose by hand. So I got a 1/2" drive breaker bar, 14" long, and rigged the car jack under it. Nice even pressure and the plugs quickly started to loosen. Just had to keep changing the blocking under the jack to keep the pressure as perpendicular to the breaker bar as possible--lotta force there, could be dangerous if it slipped. Link to comment Share on other sites More sharing options...
wtdash Posted August 6, 2007 Share Posted August 6, 2007 To answer your question, I paid $19.99 for the drain and fill for the rear (and the front) including the gear oil. I used a breaker bar too. They were very tight on my 'new' (to me) '91 VLSD when I recently checked it. Link to comment Share on other sites More sharing options...
floater Posted August 9, 2007 Author Share Posted August 9, 2007 I used a breaker bar, wd40, pb blast, put a 3 ton floor jack under the breaker bar and all it didn't do anything but start to move the car up in the air. The funny thing is I removed these 36k miles ago to change the gear oil myself and torqued it down. I do take the car up in the snow in the winter. Anyway, I figure its worth it to let someone else get them out. Link to comment Share on other sites More sharing options...
msmithmmx Posted August 9, 2007 Share Posted August 9, 2007 I paid 60.00 for front and back dif Link to comment Share on other sites More sharing options...
eryque Posted August 9, 2007 Share Posted August 9, 2007 FWIW, I think the Valvoline quick-change places here charge $15.99 Link to comment Share on other sites More sharing options...
idosubaru Posted August 9, 2007 Share Posted August 9, 2007 i asked a shop to loosen mine for me so i could do it myself. they didn't charge me. but now i'd do what you said, just pay a few dollars to have it done. that's very odd that the jack under the handle didn't get it loose. i'd bet it wasn't perpendicular or was bending too much, that is bizarre for it be that tight. Link to comment Share on other sites More sharing options...
ericem Posted August 9, 2007 Share Posted August 9, 2007 Maybe you need a torch Link to comment Share on other sites More sharing options...
