Tosh Posted August 7, 2007 Share Posted August 7, 2007 Wiring harness is done (except for the alternator stuff and running my own power wires) Belts and gaskets are all swapped around. My adapter plate is in the mail and everything else is "good to go" anyone have any sugestions on the best way to install a EJ22e radiator in my GL-10 wagon ? also any hints on fan mounting would be a big + thanks guys:D Link to comment Share on other sites More sharing options...
suberdave Posted August 7, 2007 Share Posted August 7, 2007 Rad fan. take the A/C condensor out and throw it away. now you have room for the elec. fan in front of the rad. -=Suberdave=- http://www.suberdave.com Link to comment Share on other sites More sharing options...
kingbobdole Posted August 14, 2007 Share Posted August 14, 2007 I'm gonna ask this... Why? The EA82T is much harder to cool then a EJ22... you stock rad should be just fine. I'm running my Rx's single row(stock form, but not stock one) and I have a SOHC EJ25. Runs cool. Link to comment Share on other sites More sharing options...
Numbchux Posted August 14, 2007 Share Posted August 14, 2007 yep, my loyale rad keeps my 22e plenty cool. I just found out the relay for my rad fan circuit died.....huh.....never even noticed. Link to comment Share on other sites More sharing options...
Tosh Posted August 15, 2007 Author Share Posted August 15, 2007 stock rad is clogged worse then you can imagine the radiator shop I took it to wanted $50 just to "take a look at it" of corse this was after 4 days and I had already given them the radiator to "look at" IE its not worth $50 to get a broken radiator back so I told them to f off. and I just so happen to have an EJ22e radiator right here. so Its gonna have to work. Link to comment Share on other sites More sharing options...
Numbchux Posted August 15, 2007 Share Posted August 15, 2007 yea, but do you have the time and fabrication skills/equipment to make it work? go to a junkyard, and get yourself a decent loyale radiator. it'll fit right in, and the lower outlet points straight out (instead of the steep upward angle like the GL ones). Link to comment Share on other sites More sharing options...
Tosh Posted August 15, 2007 Author Share Posted August 15, 2007 I've got a grinder and a welder what else do I need ? I really just need to know where I should put it / cut to put it Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 15, 2007 Share Posted August 15, 2007 http://www.ultimatesubaru.org/forum/showthread.php?t=75028&highlight=radiator Here's a thread with some pics of the modifications. Link to comment Share on other sites More sharing options...
