Ej22 head tighting procedure?
I have a 1990 Ej22 engine that I am trying to change the headgaskets on.I tired following the chiltons tighteng procedure and ended up with no tightness on any bolt.So what is the procedure?Please help.I have to return the engine hoist by 5:30 today.
From my manual:
oil washers and bolt threads
Tighten to 22 ft lbs
3 1 6
5 2 4
Tighten to 51 ft lbs
Back off 180 degrees first, then another 180 degrees
Tighten #1, #2 to 25 ft lbs ( 27.1 ft lbs Turbo)
Tighten #3, #4, #5, #6 to 11 ft lbs (14 ft lbs turbo)
Tighten all bolts 80-90 degrees (in sequence), DO NOT EXCEED 90 degrees
Finish tighten another 80-90 degrees (in sequence), DO NOT EXCEED 90 degrees
This is what my 1992 manual suggests.
Here's what's in Haynes
Same bolt patern as in previous post.
3 1 6
5 2 4
1) All to 22 ft-lbs
2) All to 51 ft-lbs
3) Loosen all 180 degrees
4) Loosen all additionnal 180 degrees
5) 1 and 2 only to 25 ft-lbs (non turbo charged, 27 if turboed)
6) 3, 4, 5 and 6 132 in-lbs (non turboed, 168 in-lbs if turboed)
7) Tighten all bolts an additionnal 90 degrees
8) Tighten all bolts an additionnal 90 degrees
NOTE THAT (6) IS IN IN-LBS AND NOT FT-LBS.
Same thing as in Chilton's it seems.
Since I'm about to remove and replace the left head of my engine, I also would like to know if those numbers are good.
Hope that helps.
This is going to show how much I don't know, but...
Why wouldn't you just tighten to final spec using an appropriate star pattern? Why this tightening-loosing-tightening routine?
And howcome the spec isn't the same for all of the bolts? I'd think that would cause the head to warp.
To loosen in mid-sequence is to "crush" the gasket then release for a proper fit when tightened again. These are a multiple plate head gasket and require this prior to installation. The different spec for 1 & 2 woulb be something those little japanese guys across the pond gettin paid 6 figures a year decided was a good idea, and works... haven't seen a failure yet from this method....
Lewis
Oddly enough, my British/European Haynes is different on the "pre-tighten", claiming center bolts to 34 ft lbs (#1+#2), rest to 15 ft lbs, making no distinction for turbo charged, or not, then finish up with the two 90 degree tightens.
Go figure?
I'd go with the "official" Subaru manual.
one of the holes for an idler striped out!!!!
If it is the tensioner bolt, that bit is Subaru part number #13086AA012
You would clean up the thread with a tap (12mmX1.25, I *think*) and try a longer bolt (but not too long, you don't want to bottom out in the hole), being very careful not to finish the job on the hole.
Helicoil?
It is really not a *good idea* to try magic gumbo (concoctions of epoxy) on the camshaft drive.
