guidance1 Posted August 10, 2007 Share Posted August 10, 2007 The plastic headlight units on my 96 Legacy are so fogged over its cutting down on the output. I found some units but they're $150 ea. Is there another answer or? Thanks Link to comment Share on other sites More sharing options...
Huck369 Posted August 10, 2007 Share Posted August 10, 2007 You can usually buff them back out... I use a product called "Novus" it's a 3 part set that is made for motorcycles windshields. Link to comment Share on other sites More sharing options...
porcupine73 Posted August 10, 2007 Share Posted August 10, 2007 There's a number of kits available to help with this issue. Generally they include something to sand or buff out the haziness, then some sort of sealer that is supposed to prevent the haziness from returning. I haven't used any such kit yet so I'm not sure which ones are good. Link to comment Share on other sites More sharing options...
nipper Posted August 10, 2007 Share Posted August 10, 2007 many many many posts on this here and on the net. Usually it involves sanding, polishing then sealing the lense. DO a search here and on google. nipper Link to comment Share on other sites More sharing options...
