The mounts can visually look ok, but still be torn apart. I had a set of the round style that fell apart when I took out the motor on one of the legacy's.
If you stand over the motor and rev it up manually, does it seem like the engine is twisting off the crossmember excessively?
If you can get under the car you can inspect the tranny mount visually, and also jack it up some and see what the mount looks like when put under stress.
