brighton98 Posted August 15, 2007 Share Posted August 15, 2007 I checked my knock sensor yesterday; it was uncracked so I reinstalled it. Now the car starts but won't keep running. You can catch it before it stalls, but dies again even if you stay on the gas. I checked for loose vacuum lines, wires, etc. I did spray out the throttle body while the airbox was off, but I've done that before with no ill effect. I'm really @#$%ed-please help! Quote Link to comment Share on other sites More sharing options...
nipper Posted August 15, 2007 Share Posted August 15, 2007 WHat did you spray the throttle body with? Do you have spark? nipper Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 15, 2007 Share Posted August 15, 2007 Check the 1" rubber hose that hooks to the Idle air control motor from under the main air intake pipe. If that's off, it will start but not run, and it's under the main intake hose so it's easy to forget. Quote Link to comment Share on other sites More sharing options...
brighton98 Posted August 15, 2007 Author Share Posted August 15, 2007 WHat did you spray the throttle body with? Do you have spark? nipper I used CRC Air Intake Cleaner, same as always. Must have spark because it starts, idles fine for 6-7 seconds, then dies. Quote Link to comment Share on other sites More sharing options...
nipper Posted August 15, 2007 Share Posted August 15, 2007 I used CRC Air Intake Cleaner, same as always. Must have spark because it starts, idles fine for 6-7 seconds, then dies. not nessacarily. it can die from loss of fuel or park. nipper Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 15, 2007 Share Posted August 15, 2007 Check the 1" rubber hose that hooks to the Idle air control motor from under the main air intake pipe. If that's off, it will start but not run, and it's under the main intake hose so it's easy to forget. This sounds like the winning ticket. I did that yesterday when working on mon's 98 legacy. Same exact symptoms as the poster. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted August 15, 2007 Share Posted August 15, 2007 Right on, any of those 316 hoses on the intake tubing like to come off. If you had the throttle open when spraying that cleaner in there, it might take some running for it to clear it out. If it is just the cleaner in the intake, running for a while at 1/4 throttle will help clear it out. Usually they sputter and stall if you just try to let them idle after spraying cleaner in the intake. Quote Link to comment Share on other sites More sharing options...
brighton98 Posted August 16, 2007 Author Share Posted August 16, 2007 Check the 1" rubber hose that hooks to the Idle air control motor from under the main air intake pipe. If that's off, it will start but not run, and it's under the main intake hose so it's easy to forget. Bingo!! I don't know how I missed it, but the IAC hose was not hooked up at the intake plenum. Hooked it up, runs great. Thanks all--props to 91Loyale and 86BRATMAN. Quote Link to comment Share on other sites More sharing options...
