Remove an entire fuel system?
what about just a new fuel line, high volume low pressure pump back by the tank, feeding a surge tank under the hood, and install a high pressure FI fuel pump under the hood feeding from the surge tank?
Might be simpler and cheaper, definitely more effective as it is only as limited as the new fuel supply line you run... The old supply line should be ample for a return.
