TheSubaruJunkie Posted August 22, 2007 Share Posted August 22, 2007 NAPA or Kragen Link to comment Share on other sites More sharing options...
croak Posted August 24, 2007 Share Posted August 24, 2007 So get this, the Nevada Smog certificates don't give result numbers anymore. I just did mine. (passed btw) I asked the guy where you can get the numbers from, he said you can go to the emissions lab next to the main DMV, and they can get the results for you. Dalton if you go get the results and post them, I'm sure someone on here can help you indentify your problem. It should also tell you if it only failed on the visual inspection you mentioned. hope that helps croak Link to comment Share on other sites More sharing options...
Nate007 Posted August 24, 2007 Share Posted August 24, 2007 ever thought of bribing the mechanic at the smog station? Link to comment Share on other sites More sharing options...
crazy D Posted August 25, 2007 Author Share Posted August 25, 2007 ever thought of bribing the mechanic at the smog station? yes lol. thats my next try -Dalton Link to comment Share on other sites More sharing options...
NV Zeno Posted August 25, 2007 Share Posted August 25, 2007 Before going to drastic measures suggested above, why not try restoring your system to the original and complete configuration. Get the missing parts installed, do a minor tuneup, set the timing correct, do an oil change, then retest. The results, if failed, would be a HUGE help in determining where to begin looking to correct the problem. Who knows, it may even pass after trying the simple stuff. My 2 bucks Link to comment Share on other sites More sharing options...
