Turbone Posted August 22, 2007 Share Posted August 22, 2007 Young friend of mine recently got a 91 Mitsubishi Galant VR4. 2.0 4G63 turbo, etc, yadayada. The car is in great shape but the engine has a rod knock. So we are in the process of getting a rebuilt. These suckers are not cheap. A stock rebuild from PINA is almost $3K:eek: Found one on CL thats local, for $4K:rolleyes: But its been built up. Offered $3500 cash, hope to know in a few days or less if we have a engine or not. Heres a few pics. Link to comment Share on other sites More sharing options...
Phizinza Posted August 23, 2007 Share Posted August 23, 2007 Oh no.. Not Mitsubishi!!! haha... Good luck to him with the build. Link to comment Share on other sites More sharing options...
crazyhorse001 Posted August 23, 2007 Share Posted August 23, 2007 Our friends down under call them "Bits-R-Missin"...Kinda fits if you ask me. *grins* That said the Galant VR4 is a great find...DSM speed/agility in a user friendly 4dr package Link to comment Share on other sites More sharing options...
Turbone Posted August 24, 2007 Author Share Posted August 24, 2007 Our friends down under call them "Bits-R-Missin"...Kinda fits if you ask me. *grins*That said the Galant VR4 is a great find...DSM speed/agility in a user friendly 4dr package Haha, thats funny. I'll have to mention that to the kid. We are suppposed to pick up the engine this Sat evening. Its a built up one, see my other thread. Link to comment Share on other sites More sharing options...
4x4_Welder Posted August 24, 2007 Share Posted August 24, 2007 I always called them the "Missisbichy", got a few of my friends saying that now too. Having one didn't help that. Link to comment Share on other sites More sharing options...
Phizinza Posted August 24, 2007 Share Posted August 24, 2007 Our friends down under call them "Bits-R-Missin"...Kinda fits if you ask me. *grins*That said the Galant VR4 is a great find...DSM speed/agility in a user friendly 4dr package Yes, I very often do call them bits-r-missin's.. But for some reason I held that back the other day.... Still, they go pretty hard. Link to comment Share on other sites More sharing options...
Turbone Posted August 24, 2007 Author Share Posted August 24, 2007 So here I am pulling the hunk out of this thing, of course its a transvestite, I mean transverse engine:-p Do I have to pull the engine and tranny as one piece or can it be seperated? It does not look like I have enough room to slide the engine to the side enough so it can come off the tranny, etc. If the whole thing has to come out, it means more time... ie, more stuff to disconnect:-\ Man, how do I get talked into these jobs:rolleyes: Brian, if your reading this.......its the last time buddy:Flame: I'm sticking to Subaru. Know whats ironic? He has a newer V6 Mustang right now and I looked at the engine yesterday. I could have pulled that out in a couple of hours:rolleyes: Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 24, 2007 Share Posted August 24, 2007 Sad to tell you Rob, it has to come put as a unit. I've had so many transverse mounted removal and installs that it comes second nature to me. But axles, shift cables, driveshaft, and all that fun stuff has to be disconnected. You'll also have better luck getting it all out if you have a good balencer on the hoist, and let the tranny side hang lower than the motor side. And installgoes about the same way. It hasn't been but maybe two months ago I put a motor into the black talon you can see in my pics of the XT here, so if you need any input along the way pm me and I can give you some help, or at least moral support. Link to comment Share on other sites More sharing options...
82glsw Posted August 24, 2007 Share Posted August 24, 2007 As bratman said it has to come out as a whole unit. it is alot easier to take it out together then to seperate the tranny in the car. Make sure u mark all vacum line so they go back in the right place there are quite a bit of them on the 4g63t as for the wiring harness it will usually fall right back in place for each connection. Link to comment Share on other sites More sharing options...
4x4_Welder Posted August 25, 2007 Share Posted August 25, 2007 Rock-bottom easiest way is to drop it out the bottom, steering rack and all. Usually that's the only way to pull engines on compact fwd cars. Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 25, 2007 Share Posted August 25, 2007 Rock-bottom easiest way is to drop it out the bottom, steering rack and all. Usually that's the only way to pull engines on compact fwd cars. For this car in particular. it would require dropping the entire k-member, and the front and rear crossmembers it attaches to. I've done more motor swaps and tranny swaps(mostly in hondas) than some kids my age have seen neon lighting. Having an extra set of hands is helpful, but its not required to do it in the method I described. Link to comment Share on other sites More sharing options...
Turbone Posted August 25, 2007 Author Share Posted August 25, 2007 Alrighty then, not what I wanted to hear. But glad I got to hear it before I really started yanking on it:rolleyes: The more I looked at it, the more sence it made to pull it all out at the same time. So whats the trick on the axles? Is it anything like ours? Do I need to pull the bottom ball joint out, etc? I have a CD manual, I've already spent a couple of hours reading it. And of course it didnt mention anything about pulling both units together:-\ Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 25, 2007 Share Posted August 25, 2007 Drain the transmission fluid, remove lower ball joints, and pry the alxes out with a small pry bar. They are slip in style, held with a circlip like the 96+ rear axles on our cars. If the axles warrent replacement while you're doing this you'll have to remove the front strut mount fork from the lca and strut. Link to comment Share on other sites More sharing options...
82glsw Posted August 25, 2007 Share Posted August 25, 2007 Dont let the car intimadate u there not that bad to work on. the first motor swap i ever did was a 91 mitsubishi eclipse with the same motor as the galant. if you take ur time it wont be bad at all Link to comment Share on other sites More sharing options...
Turbone Posted August 27, 2007 Author Share Posted August 27, 2007 Yes thay are:mad: They suck to work on. I had to lift the engine just to get the last bolt on th ac compressor. Way to much stuff to disconnect:rolleyes: The engine wont come out with just a chain from the hoist. I have to go to Harbor Freight today and get a load balancer because it has to be tilted almost vertically to get it all out. If this was a Subaru, it would be back on the road by now. Link to comment Share on other sites More sharing options...
82glsw Posted August 28, 2007 Share Posted August 28, 2007 Hopefully everything else goes well for you. glad to hear its almost out Link to comment Share on other sites More sharing options...
Turbone Posted August 28, 2007 Author Share Posted August 28, 2007 I bought a load balancer today, but didnt have a chance to use it:-\ Tomorrow that sucker is coming out. Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 29, 2007 Share Posted August 29, 2007 How's it coming man? Got that bad boy out yet? Link to comment Share on other sites More sharing options...
Turbone Posted August 29, 2007 Author Share Posted August 29, 2007 Yup, got it out yesterday. Have to wait for the new engine to get here, not sure how long it will be, but I get a break and can work on some of my stuff now. My SVX is getting a new speed sensor on Fri and thats a PITA to do (under car). Link to comment Share on other sites More sharing options...
82glsw Posted September 7, 2007 Share Posted September 7, 2007 any new news on this project Link to comment Share on other sites More sharing options...
Rooinater Posted September 8, 2007 Share Posted September 8, 2007 your yard is now tainted... Link to comment Share on other sites More sharing options...
Turbone Posted September 9, 2007 Author Share Posted September 9, 2007 your yard is now tainted... Dont worry, its outnumbered;) Especially after today:rolleyes: Link to comment Share on other sites More sharing options...
Turbone Posted September 9, 2007 Author Share Posted September 9, 2007 any new news on this project Still waiting for the engine to come in. It was suppossed to be here this week, but they say the Holiday on Monday screwed shipping up:rolleyes: Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 9, 2007 Share Posted September 9, 2007 Dont worry, its outnumbered;) Especially after today:rolleyes: What is it this time? Link to comment Share on other sites More sharing options...
Rooinater Posted September 10, 2007 Share Posted September 10, 2007 Dont worry, its outnumbered;) Especially after today:rolleyes: lol... Link to comment Share on other sites More sharing options...
