August 23, 200718 yr 2000 legacy 130K, abs light comes on and stays on when i drive with my headlights on, anyone with any ideas or insight would be greatly appreciated, oh original battery was replaced yesterday with no change in condition.
August 23, 200718 yr abs light comes on and stays on when i drive with my headlights on Very very good chance your alternator is dying. The ABS light and some other indicator lights get their ground through the alternator field circuit, so if the alternator is going flaky these lights may come on or flicker. This is definitely something to check out right away or otherwise prepare for to avoid being stranded.
August 23, 200718 yr ABS = dying altenator ABS + brake = impeding doom ABS + Brake + Battery = pull over NOW Get your charging system load tested. Make sure they test it at 2000 RPM with everything on in the car. nipper
