Hodaka Rider Posted August 24, 2007 Share Posted August 24, 2007 So, I have not been able to make it to a 'yard for awhile, but had a friend drop by a few pieces of linkage from his collection. So, can anyone tell me what I'm missing? Link to comment Share on other sites More sharing options...
Hodaka Rider Posted August 28, 2007 Author Share Posted August 28, 2007 Bum-pi-ty Link to comment Share on other sites More sharing options...
nipper Posted August 28, 2007 Share Posted August 28, 2007 The car that it attaches to? nipper Link to comment Share on other sites More sharing options...
j2coe Posted August 28, 2007 Share Posted August 28, 2007 might work better with the rest of the car. what are you doing with it? replacing another one, do you have the original out of your car? swapping a different tranny? kind of need a story to go woth the part. Link to comment Share on other sites More sharing options...
Hodaka Rider Posted August 28, 2007 Author Share Posted August 28, 2007 Sorry, I guess I just thought some people might remember my previous postings on swapping a D/R into my Loyale, the pics of the D/R without linkages, etc. This linkage is from a EA-82 D/R trans, not sure of the year though. Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 29, 2007 Share Posted August 29, 2007 There is the bracket that the linkage pivots on. The two bolts that hold the rubber mount to the back of the main shifter plate also hold a bracket for that rubber bushing in the D/R handle. You need this bracket, as the loyale will not have it. Link to comment Share on other sites More sharing options...
Hodaka Rider Posted August 29, 2007 Author Share Posted August 29, 2007 Kinda what I thought. I'm guessing you kinda need to remove it from underneath too, right? Link to comment Share on other sites More sharing options...
hyrysc Posted August 29, 2007 Share Posted August 29, 2007 The car that it attaches to? nipper bwhahahahaaa:lol: Link to comment Share on other sites More sharing options...
Hodaka Rider Posted September 12, 2007 Author Share Posted September 12, 2007 OK, got me some more: That should do 'er, right? Are those two studs on top of the 4WD lever pivot for a switch? Link to comment Share on other sites More sharing options...
thealleyboy Posted September 12, 2007 Share Posted September 12, 2007 Yeah, there is a contact switch that mounts up top. I don't think it is required, but you might want a second opinion... There may be a few misc. pieces you'll still need to finish the job. Depending on what came with your D/R, you may need a mounting bracket that hold the shifter rod in place. Also, there is a spring underneath that ties the shift rod to the housing. Don't forget all the bushings and stuff that always seems to get misplaced anytime you do a conversion. Good Luck, John Link to comment Share on other sites More sharing options...
Hodaka Rider Posted September 12, 2007 Author Share Posted September 12, 2007 Thanks John. My D/R is from a newer car, so all indicator light switches are on the tranny. I think I've got it covered now, thanks for the input. (unless anyone else has something to say) Link to comment Share on other sites More sharing options...
thealleyboy Posted September 12, 2007 Share Posted September 12, 2007 I don't know if you've done the pedal box and speedo yet (A/T conversion?), but I always treat those items as if they are part of the D/R "linkage" conversion. Namely, you'll want to look at the clutch cable, and replace if necessary, before bolting up the pedal box. The old cable is often frayed, and the end fastener assembly corroded. These cables can be difficult to replace by crawing under the dash. Also, I would make sure both ends of the correct speedo cable are intalled before buttening up your steering column, and bolting the tranny completely. Speedo cables are also difficult to replace after the fact, and screwing them into the tranny can be frustrating. good luck, John Link to comment Share on other sites More sharing options...
Hodaka Rider Posted September 12, 2007 Author Share Posted September 12, 2007 Mine's already a 5spd, pushbutton. Just need the low range! Link to comment Share on other sites More sharing options...
