Cam Timing Ea82t
I have just done some more upgrades to my baby , 3 inch wrx zorst ,td04 and new heads. Now with it all back together I'm not sure whether I've got the cams lined up properly. With the three cam marks on the fly wheel lined up should the drivers side cam (Australian driver's side) be pointed straight up at twelve o clock and the alternator side pointing straight down at 6 o clock? Don't know if I've got it the right way or not. Thanks for any help.
the passenger side of your car should be pointing straight up, put the belt on, then roate the engine 360 degrees to point the passenger side down. Then point the driver side up and put that belt on. Always start with the belt that is on the distributor side of the engine.
