Zefy Posted August 26, 2007 Share Posted August 26, 2007 alright got a few questions for all of you. first off the rad hosing. now i know the standard is to use some sort of adaptor to get your hose from 1-1/8 to 1-1/4. i got that covered. the issue is the bottom port on the rad sits a whopping 1/2-3/4" from the timing belt cover... i alread got a couple of ideas to fix this. key being cheap. but not so cheap it doesn't work... wanted some opinions. second. wiring the alt. i'm going from a external reg alt to an internal reg one. i got the connector going off the alt plus the big power lead. big one goes to bat obviously. what about the connector though? thanks for the help! Greg, Link to comment Share on other sites More sharing options...
Zefy Posted August 27, 2007 Author Share Posted August 27, 2007 since nobody is jumping in on this i thought i'd tell you how i solved it incase anybody else runs into this problem... not sure if it's completely solved yet, but i ended up moving the two mounting pegs 2 inches to the driverside and about 1/2-3/4" towards the grill. this gave me an ok amount of clearance. i think with the right pipe it will fit fine. with that problem solved i had to move the top mounting bolts. my fan no longer fit quite like it did when i first bought it. i had to move bend the centre rad support slightly for it to clear and also take a chunk out of my headlight housing. now it seems to all fit! Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 28, 2007 Share Posted August 28, 2007 TTIWWOP! Show us some pics mang! I wanna see this:banana: Link to comment Share on other sites More sharing options...
Zefy Posted August 28, 2007 Author Share Posted August 28, 2007 TTIWWOP! Show us some pics mang! I wanna see this:banana: haha you're gonna laugh at me. my swap is kinda ghetto... engine looks like ************, but assuming i rebuilt it right, it should run like a champ! i could write a novel about all the different stuff going into this brat but i'm far to lazy to type it all out. things of note: 5 lug 2 pot 2.5RS brakes with hotbits rally coilovers CAMBER!!! ENGINE!!! rad clearance issue i've been complaining about... think it'll work like this? engine and trans together via mudrat adaptor plate whole build here: http://s118.photobucket.com/albums/o95/Zefy_88/brat/ i will be making a full build up thread once i'm done... trying to kinda keep this on the down low.:-p Link to comment Share on other sites More sharing options...
s'ko Posted August 29, 2007 Share Posted August 29, 2007 AWESOME :clap: Make me want to get a 1st gen BRAT to play with.... I would probably do a midengine RWD EJ BRAT BW Link to comment Share on other sites More sharing options...
Pooparu Posted September 5, 2007 Share Posted September 5, 2007 Great work. I can't wait to see it all finished. I did an ea81 swap on my 78 brat. Less work, less wires, less power, less cool, but still fun. Please keep posting photos. Are you doing the swap on the yellow brat you brought to WCSS7? Link to comment Share on other sites More sharing options...
Zefy Posted September 5, 2007 Author Share Posted September 5, 2007 haha nice pic. i like it! and ya it's the same brat. well... pretty much none of it is the same. but in theory it's the same brat.:-p Link to comment Share on other sites More sharing options...
monstaru Posted September 5, 2007 Share Posted September 5, 2007 thats sick mate......... Link to comment Share on other sites More sharing options...
kiwi subbie Posted January 12, 2008 Share Posted January 12, 2008 thats so cool:grin: Link to comment Share on other sites More sharing options...
ShawnW Posted January 14, 2008 Share Posted January 14, 2008 For this: I had a radiator shop install a larger pipe at an angle and braze it in. I then used a Napa flex hose (coiled in the middle and rubber ends) to connect. They even make these with 2 different sized ends. Link to comment Share on other sites More sharing options...
Zefy Posted January 15, 2008 Author Share Posted January 15, 2008 it took a little bit of playing but i actually got it to work with the way it is in the pic. if this doesn't work out i'll bring it to a rad shop to get worked on... thanks for reviving my thread folks!:cool: Link to comment Share on other sites More sharing options...
Zefy Posted January 15, 2008 Author Share Posted January 15, 2008 oh and while i have everybody looking, what are these two wires for!?! one is white w/ green the other is green w/e white...? Link to comment Share on other sites More sharing options...
the_postie Posted January 17, 2008 Share Posted January 17, 2008 This is a write up i did for putting any subaru alt into any model. http://www.ausubaru.com/forum/showthread.php?t=4260 Will Link to comment Share on other sites More sharing options...
Subarutex Posted January 17, 2008 Share Posted January 17, 2008 Zefy... if I recall those two wires are for the oil pressure light and the water temp light. Rad hose looks good. What kind of pipe do you have between them? I would reccomend copper, as it will last the best, and won't potentially release stuff into your cooling system. And lastly... do you think we'll see this at WCSS X? Link to comment Share on other sites More sharing options...
Zefy Posted January 17, 2008 Author Share Posted January 17, 2008 This is a write up i did for putting any subaru alt into any model.http://www.ausubaru.com/forum/showthread.php?t=4260 Will that writeup is good thanks! the main difference between that and my old gen1 is the regulators on those alternators are internal. mine is external and so there are a lot wires on this beast... they changed this with the introduction of the ea81. however i believe i've semi sorted the problem out. thanks! Link to comment Share on other sites More sharing options...
Zefy Posted January 17, 2008 Author Share Posted January 17, 2008 Zefy... if I recall those two wires are for the oil pressure light and the water temp light. Rad hose looks good. What kind of pipe do you have between them? I would reccomend copper, as it will last the best, and won't potentially release stuff into your cooling system. And lastly... do you think we'll see this at WCSS X? thanks for the wiring help! that makes sence now... my tentative date to have it running is mid february for iceX. this date, like all the others, will probably not be accomplished. the key components that i need to complete it are very close to being mine. then i just need to suck it up and work in the cold... however if it isn't ready for wcss10 then somebody kick me...:-p Link to comment Share on other sites More sharing options...
rguyver Posted January 31, 2008 Share Posted January 31, 2008 "however if it isn't ready for wcss10 then somebody kick me...:-p" Im closest i'll kick first Link to comment Share on other sites More sharing options...
kiwi subbie Posted February 7, 2008 Share Posted February 7, 2008 what kinda hubs are you using on on this? are they xt6 ones? Link to comment Share on other sites More sharing options...
Zefy Posted February 7, 2008 Author Share Posted February 7, 2008 front hubs are from a 2.5RS.. i wanted the larger brakes... Link to comment Share on other sites More sharing options...
kiwi subbie Posted February 7, 2008 Share Posted February 7, 2008 front hubs are from a 2.5RS.. i wanted the larger brakes... done any thing about the back? and was it difficult 2 fit those to the front? what did you have to do? Link to comment Share on other sites More sharing options...
Zefy Posted February 7, 2008 Author Share Posted February 7, 2008 i'm not going to post anything about the rear suspension until it is complete... don't want to give people false hope! so to fit the fronts i got in touch with crossbread performance and got a set of their front control arms... i then had to move the stabalizer bar from the gen1 control arm onto the new one. something like such: then i installed them. you will also need lengthen the tie rods... haven't put to much thought into this... solutions are to sleave the old ones to make them longer or use newer gen longer tie rods... drill the strut top or get these wacky adaptor kits from crossbread performance and use your stock strut top... i opted for going with pillowball top mounts so using the stock mounting points won't work... strengthen the strut tower and drill new holes to suit the 2.5rs strut. which is the next problem... 2.5rs struts (or springs rather) are to wide to fit in the tiny towers... coilover type springs solves this problem... there are cheap ways to fix this (ground control style coilovers) and there is expencive coilovers. i opted for full rally grade hotbits coilovers... (using these coilovers is backfiring on me right now but hopefully i'll find a solution...) then you need to get shortened axles (different inner cups depending on the transmission being used) which i got from rguyver on the board here... stock 2.5rs axle compared to my custom super duper axle... Link to comment Share on other sites More sharing options...
rguyver Posted February 7, 2008 Share Posted February 7, 2008 the rear Xt6 hubs should just fit on like the later EA82 cars and the disc brake backing should fit too , my friend did the 4 bolt disc brake swap on his gen 1 brat and the XT6 5 bolt goes on the same . Link to comment Share on other sites More sharing options...
Zefy Posted February 7, 2008 Author Share Posted February 7, 2008 does anybody have any pictures of the rear disc brake swap goes onto the gen1? i already did the 4 lug rear disc swap but from what i saw with the xt6 stuff is you have to swap the trailing arms aswell which are not the same.. also with doing this swap i don't think i'll be able to fit big enough tires for my application... a solution needs to be found! mine is quite complicated and annoying however if it works it'll be kickin... if i can just swap some xt6 stuff on it would save me time and money however i would need smaller tires... anybody have a solution for this that i may have not thought of? Link to comment Share on other sites More sharing options...
filonin_2 Posted August 2, 2010 Share Posted August 2, 2010 Sorry for the thread resurrection, but did a build thread ever happen? Link to comment Share on other sites More sharing options...
Zefy Posted August 2, 2010 Author Share Posted August 2, 2010 ummmm sort of... I kinda stopped updating it a while back. the build is still going on. VERY SLOWLY... it now lacks the simplicity that i first set out with. tee hee... here is a link to my photobucket with pretty much all the pictures of the work i've done up till the middle of last year or so. There is also some throttle body stuff in there as well but that's a little bit if a different project. http://s118.photobucket.com/albums/o95/Zefy_88/brat/?start=260 i am now working full time again making the moneyz. so I just had my rear drive shaft made. Should be ready on tuesday because monday is a holiday!!! WOOO... So many little things to do. Today i spent my time with weather stripping, rebuilding the wiper motor, and installing some body panels. My maf sensor appears to be bad so i can't start the engine. Fuel system needs some work as i think it leaks a bit. Also i'm not supposed to run fuel with ethanol in it with the fuel cell and walbro... so much to do, wcss is around the corner just waiting for my to fail! Link to comment Share on other sites More sharing options...
