Legacy777 Posted December 6, 2003 Share Posted December 6, 2003 I posted this on legacycentral....but figured I wouldn't leave you out of the dark Well....I wouldn't want you guys to think I don't like you and not get you a Christmas present.....so I'm going to inundate you with info.Larry posted a link over on the BC-BF List for these parts & service manuals. This guy apparently scanned them in because he used an EJ22 motor in his airplane. Well the scans were a little hard to navigate....so being me, I added bookmarks to the pdfs so you have a nice index structure to see what's all in the pdf. The FSM & Parts manuals only include the engine/electrical pages, but contain most of the important stuff.Here's the original sitehttp://www.finleyweb.net/default.asp?id=142Please right click and save the pdf's. Thanks!Here is the root link for all the service manualshttp://www.main.experiencetherave.com/subaru_manual_scans/1992 FSM (Engine & Electrical)http://www.main.experiencetherave.com/subaru_manual_scans/1992_FSM_Eng_and_Elect/1990-1994 Parts Manualhttp://www.main.experiencetherave.com/subaru_manual_scans/1990-1994_Legacy_Parts_Catalog_-_FULL/ 1992 Service Bulletinshttp://www.main.experiencetherave.com/subaru_manual_scans/Subaru_Service_Bulletins/Don't forget the other scans I already have there.Also, some of you know this, but I have scanned my entire owner's manual as well.You can look at each page or d/l a complete pdf filehttp://www.main.experiencetherave.com/owner/Like I said, there's A LOT of info in these pdf's. The service bulletins have a lot of good info too.Enjoy 1 Link to comment Share on other sites More sharing options...
Legacy777 Posted December 6, 2003 Author Share Posted December 6, 2003 Now for the index of everything 1990-1994 Subaru Legacy Parts Manual – Engine* Illustrated Index* Group Index* Short Block Engine* Gasket & Seal Kit (Engine)* Cylinder Block* Timing Hole Plug & Transmission Bolt* Cylinder Head* Piston & Crankshaft* Flywheel* Camshaft & Cambelt* Valve & Valve Rocker* Rocker Cover & Oil Filler Duct* Timing Belt Cover (To Dec ’92)* Timing Belt Cover (From Jan ’93)* Oil Pan* Oil Pump & Oil Filter* Oil Cooler; Turbo (‘91MY)* Water Pump; NA* Water Pump; Turbo* Turbo Charger System* Intake Manifold; NA (’90 & ‘91MYS)* Intake Manifold; NA (’92 & ‘94MYS)* Intake Manifold; Turbo* Air Cleaner* Air Duct* Fuel Pipe System* Fuel Injector* Engine Cooling System; NA* Engine Cooling System; Turbo* Throttle Body & Air Duct* Alternator Bracket & V Belt* Spark Plug & High Tension Cord* Wiring Harness-Engine; NA* Wiring Harness-Engine; Turbo* Starter (1) MT (1.0KW)* Starter (2) AT (1.4KW)* Alternator* Hose & Clamp (P.C.V.); NA* Hose & Clamp (P.C.V.); Turbo* Emission Cont System; Turbo* Engine Electrical Parts 1992 FSM (Engine & Electrical)* Table of Contents* 1-1 Specifications* 2 Engine Section Index* 2-1 Emission Control System and Vacuum Fitting* System Application* Schematic Drawing* General Precautions* Crankcase Emission Control System* Ignition Control System* Evaporative Emission Control System* Vacuum Fitting* 2-2 On-Car Services* Foreword* Engine Compression* Intake Manifold Vacuum* Hydraulic Lash Adjuster* Fuel Injector* Oxygen (O2) Sensor* 2-3 Engine* Mechanism and Function* General* Timing Belt* Belt Tension Adjuster* Belt Cover* Valve Rocker ASSY* Hydraulic Lash Adjuster* Cam Shaft* Cylinder Head* Cylinder Block* Crankshaft* Piston* Specifications and Service Data* Specifications* Service Data* Component Parts* Timing Belt* Cylinder Head and Camshaft* Cylinder Head and Valve ASSY* Cylinder Block* Crankshaft and Piston* Service Procedure* General Precautions* Timing Belt* Valve Rocker ASSY* Camshaft* Cylinder Head* Cylinder Block* Troubleshooting* Engine Trouble in General* Engine Noise* 2-4 Engine Lubrication System* Mechanism and Function* General* Lubrication Lines* Oil Pump* Oil Filter* Oil Pan & Oil Strainer* Oil Pressure Switch* Specifications and Service Data* Component Parts* Oil Pump* Service Procedure* Oil Pump* Troubleshooting* 2-5 Engine Cooling System* Mechanism and Function* General* Cooling Lines* Water Pump* Mechanical Seal* Thermostat* Coolant Filler Tank* Specifications and Service Data* Specifications* Service Data* Component Parts* Water Pump* Radiator and Radiator Fan* Water Pipe* Service Procedure* Water Pump* Thermostat* Radiator* Radiator Cap (Filler Tank Cap on Turbo Model)* Radiator Fan and Fan Motor* Coolant Filler Tank* Troubleshooting* 2-7 Fuel Injection System* Mechanism and Function* General* Air Line* Fuel Line* Sensor and Switch* Control System* Self-diagnosis System* Turbocharger System* Component Parts* Intake Manifold* Air Intake Duct and Throttle Body* Air Cleaner* Turbocharger Unit* Service Procedure* Turbocharger System* Troubleshooting* Supplemental Restraint System “Airbag”* Precautions* Pre-inspection* Troubleshooting Chart for Self-diagnosis System* Output Modes of Select Monitor* Control Unit I/O Signal* Troubleshooting for Engine Starting Failure* Troubleshooting Chart with Trouble Code* Troubleshooting Chart with Select Monitor* General Troubleshooting Table* 2-8 Fuel System* Mechanism and Function* Fuel Lines* Specifications and Service Data* 6-1 Engine Electrical System* Specifications and Service Data* Component Parts* Starter* Alternator* Service Procedure* Starter* Alternator* Spark Plug* Ignition Coil* Spark Plug Cord* Troubleshooting* Starter* Alternator* 6-2 Body Electrical System* Engine Electrical (MPFI)* Radiator Fan* Lighting* Cruise Control* 6-3 Wiring Diagram and Troubleshooting* General Description* Working Precautions* How to Use Wiring Diagram* How to Use Super Multiple Junctions (S.M.J.)* Wiring Diagram and Troubleshooting* Power Supply Routing* Charging* Starting* Engine Electrical* Radiator Fan* Lighting (Headlight)* Lighting (Tail, Illumination, etc.)* Room Light and Door Switch* Stop Light* Turn Signal and Hazard* Trunk Room Light* Back-up Light* A/T Control* A/T Shift Lock* Electrical Unit Location* Compressor Map – IHI BRL4016 (EJ22 Turbo) 1992 Subaru Service Bulletins* 2.2L 4-Cyl & 2.2L 4-Cyl Turbo – VIN (6)* Removal & Installation* Overhaul* Engine Oiling* Water Pump R & I* Torque Specifications* Engine Specifications* Interference Verification Check for OHC Engine* Specifications* Capacities* Quick-Service* Mechanical Checks* Ignition System* Fuel System* Theory/Operation* Air Induction System* Computerized Engine Controls* Fuel System (Carbureted)* Fuel System (Fuel Injected)* Ignition Systems* Emission Systems* Self-Diagnostics* Basic Testing* Fuel System* Ignition Checks* Idle Speed & Ignition Timing* Fuel Pump Circuit Tests* Tests W/Codes* Self-Diagnostic System* Diagnostic Code Charts* Read Memory Mode* D-Check Mode* Clear Memory Mode* Crank Angle Sensor* Starter Switch* Cam Angle Sensor* Fuel Injectors* Coolant (Water) Temperature Sensor* Knock Sensor* Airflow Meter Circuit* By-pass Air Control Valve* Throttle Position Sensor* Oxygen (O2) Sensor* Vehicle Speed Sensor No. 2* Canister Purge Control (CPC) Solenoid Valve* Air/Fuel Ratio Control System* Idle Switch* Wastegate Control Duty Solenoid Valve (Turbo)* Pressure Sensor Duty Solenoid* Atmospheric Pressure Sensor (Non-Turbo)* Airflow Sensor* Neutral Safety Switch (Man. Trans.)* Inhibitor Switch (Auto. Trans.)* Parking Brake Switch (Auto. Trans.)* Tests W/O Codes* Symptom Diagnosis (Carbureted – Justy)* Justy Symptom Diagnostic Chart* Loyale Symptom Diagnostic Chart* Legacy Symptom Diagnostic Chart* SVX Symptom Diagnostic Chart* Intermittent Problem Diagnosis* Wiring Diagrams* Wiring Diagram (Legacy 2.2L PFI & Turbo)* Component Location Menu* Engine Compartment, Headlights (Grid 1-3)* MPFI Control Unit (Non Turbo), Ignition Relay (Grid 4-7)* Check Connector, Ignition Coil (Non Turbo) (Grid 8-11)* MPFI Control Unit (Turbo) (Grid 12-15)* Check Connector, Ignition Coil (Turbo) (Grid 16-19)* Fuse Relay Box, Ignition Switch (Grid 20-23)* A/T Control Unit, Shift Lock Control Unit (Grid 24-27)* ABS Control Unit, Cruise Control Unit (Grid 28-31)* Air Suspension Sensors, Height Control Unit (Grid 32-35)* A/C Relay Box, Air Bag Control Unit (Grid 36-39)* Front Wiper Motor, Hazard Sw (Grid 40-43)* Instrument Cluster, Dome Light (Grid 44-47)* Auto Shoulder Belt Control Unit, Pwr Windows (Grid 48-51)* Power Mirror/Sunroof Sw, Tail Lights (Grid 52-55)* Electrical Component Locator* Buzzers, Relays, & Timers* Circuit Protection Devices* Control Units* Motors* Sending Units & Sensors* Solenoids & Solenoid Valves* Switches* Miscellaneous* Trouble Code 13 – Crank Angle Sensor* Vacuum Diagrams* Remove/Install/Overhaul – Turbocharger (Legacy)* Effects of Incorrect Fuel Use: New Procedure* Incorrect Oil Pump Cover Torque: New Specification* Fuel Injector Replacement* Incorrect Duty/ID/Data Charts: New Charts* Updated Line Pressure Duty Diagram (1990 Legacy)* Updated Line Pressure Duty Diagram (1991-92 Legacy)* Updated Line Pressure Duty Diagram (1992 SVX)* Updated Cartridge I.D. Chart for Select Monitor* Updated A/T Data Ranges (1990 Legacy)* Updated A/T Data Ranges (1991-92 Legacy)* Low RVP Fuel Effects: New A/T ECU-ROM Installation* Omitted Fuel Gauge Delay Amplifier: Not Used in USA Link to comment Share on other sites More sharing options...
pdigiacinto Posted December 25, 2003 Share Posted December 25, 2003 Thanks for all the information.. Looks good.. Link to comment Share on other sites More sharing options...
Ma-fia Posted December 25, 2003 Share Posted December 25, 2003 Actually, I e-mailed him, trying to find out which manual/year the info on EA-81 came from, and the guy didn't know much about what he had. My guess is that he didn't scan them himself... I wonder where he got them and what else is out there?! Too bad they don't have complete manuals for later years, as they have for 1989 -- that one is scanned PERFECTLY and is 100% complete, not just the engine section. Not that I need any of it, but I downloaded it all -- you never know. Link to comment Share on other sites More sharing options...
Legacy777 Posted October 24, 2004 Author Share Posted October 24, 2004 I've added some more goodies. All can be found herehttp://www.main.experiencetherave.com/subaru_manual_scans/Again, Please right click and save the pdf's. Thanks1980_Subaru_Manuals1990_Legacy_FSM_Supplement1990_Legacy_Owner_Manual_Scans1990-1994_Legacy_Parts_Manual_-_Engine1992_FSM_(Engine_&_Electrical)1992_Subaru_Service_Bulletins1999_Legacy_FSM2000+_Legacy_FSM2002_WRX_FSM2004_Impreza_WRX_STi_Factory_Service_ManualChiltonsFSM_ScansSubaru_Service_BulletinsTechnicians_Reference_Booklets Link to comment Share on other sites More sharing options...
Cougar Posted October 24, 2004 Share Posted October 24, 2004 Thanks for your efforts Josh. Link to comment Share on other sites More sharing options...
maximumBRAT Posted October 25, 2004 Share Posted October 25, 2004 you're awesome Link to comment Share on other sites More sharing options...
OLS Posted October 27, 2004 Share Posted October 27, 2004 Thanks, Thanks, Thanks. Great Job. Link to comment Share on other sites More sharing options...
HobbyWrench Posted January 16, 2005 Share Posted January 16, 2005 The links and documents below have been a fantastic resource for working on my '90 Legacy LS wagon. Thanks! I'm in need of the Service Manual information for Section 3, Transmission and Differential of the SubaruEJ-22 Repair Manuals. The links below (specifically, EJ22 Repair Manual2) appear to have this Section missing. Would you happen to have this also? (I'm out of work, so $$$ are an issue.) It appears I have a Duty Solenoid "B" problem (as translated by the "Power" light flashes). I have the 4EAT in my Legacy - FWD. On a related note, is there any long-term concern if I'd just ignore this? It seems to run fine (I've owned it for 9 months - put 5K miles on it - it has 170K.) Thanks! I posted this on legacycentral....but figured I wouldn't leave you out of the dark Well....I wouldn't want you guys to think I don't like you and not get you a Christmas present.....so I'm going to inundate you with info. Larry posted a link over on the BC-BF List for these parts & service manuals. This guy apparently scanned them in because he used an EJ22 motor in his airplane. Well the scans were a little hard to navigate....so being me, I added bookmarks to the pdfs so you have a nice index structure to see what's all in the pdf. The FSM & Parts manuals only include the engine/electrical pages, but contain most of the important stuff. Here's the original site http://www.finleyweb.net/default.asp?id=142 Please right click and save the pdf's. Thanks! Here is the root link for all the service manuals http://www.main.experiencetherave.com:8080/subaru_manual_scans/ 1992 FSM (Engine & Electrical) http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/ 1990-1994 Parts Manual (Engine) http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990-1994_Legacy_Parts_Manual_-_Engine/ 1992 Service Bulletins http://www.main.experiencetherave.com:8080/subaru_manual_scans/Subaru_Service_Bulletins/ Don't forget the other scans I already have there. Also, some of you know this, but I have scanned my entire owner's manual as well. You can look at each page or d/l a complete pdf file http://www.main.experiencetherave.com:8080/owner/ Like I said, there's A LOT of info in these pdf's. The service bulletins have a lot of good info too. Enjoy Link to comment Share on other sites More sharing options...
Legacy777 Posted January 17, 2005 Author Share Posted January 17, 2005 I replied to your other thread. Link to comment Share on other sites More sharing options...
