climber77 Posted August 26, 2007 Share Posted August 26, 2007 My cruise control keeps shutting off while driving. 1. It seems to work ok for a little while, then starts shutting off 2. Bumps / hills etc. don't seem to affect when it shuts off 3. I just got new tires on the car (seems unrelated?). Does anyone have any suggestions as to what could be wrong, or what I could check? My car is a 2005 Outback 4 cyl with manual transmission. Link to comment Share on other sites More sharing options...
eryque Posted August 26, 2007 Share Posted August 26, 2007 Does the circuit shut off altogether, or is it like hitting the cancel switch and you just have to set your speed again? Link to comment Share on other sites More sharing options...
Andyjo Posted August 28, 2007 Share Posted August 28, 2007 There's a TSB for the 05 OBXT MT's... they'll 1st re-flash your cruise, and if it still happens, then they have to add a spacer on the neutral position sensor. Mine does it.. but i'm also out of warrenty... Link to comment Share on other sites More sharing options...
climber77 Posted August 29, 2007 Author Share Posted August 29, 2007 Does the circuit shut off altogether, or is it like hitting the cancel switch and you just have to set your speed again? Yes, like cancel. Link to comment Share on other sites More sharing options...
