hancho3 Posted September 2, 2007 Share Posted September 2, 2007 So I am in the middle of swapping out an ea81 manifold for an ea82 manifold, there are these 2 hoses on the front of the engine that I am not sure what to do with. (pics here) http://picasaweb.google.com/KurtAbersold/HosesForBRAT I have had the hole in the manifold by the carb heli-arced shut and the hose barb that went to it is plugged. can somebody tell me what I need to do with these two hoses, I have searched the articles and came up empty. Any help appreciated thanks, -Kurt Link to comment Share on other sites More sharing options...
hatchsub Posted September 2, 2007 Share Posted September 2, 2007 Both of those hoses are coolant hoses. The one that used to go to the base of the carb u need to eliminate cause the weber does not use it. It sounds like you already took care of preping the manifold now u just need to get rid of the line. Simply pull that cylinder like thing off the steel line and put a plug on it. The other one should just plug onto your EA82 manifold. If not i dont see harm in eliminating it as well. Also while your in there you might want to find out why you have all that oil on the top of the engine. Chances are the oil fill tube is leaking. If that doesnt make sense shoot me a PM or something and I'll see if i can explain it better. Link to comment Share on other sites More sharing options...
TomRhere Posted September 2, 2007 Share Posted September 2, 2007 Pull the hose barb out of the T-stat housing on the manifold, then drill and tap hole to fit a 1/8" pipe plug. You can then put other hose from heater line onto hose barb on PS of engine block. Link to comment Share on other sites More sharing options...
