might be too big
LosDiosDeVerde86
so, i just ordered a new set of tires for my legacy that should be in tomorrow. i think they might be too big, and i'm nervous about the hassle at the garage.
215/75r15 goodyear wrangler rt/s on a 96 legacy sedan with an OB lift.
anyone have experience with this size on this model?
Dude, aren't you like the only one around here w/ a lifted legy' sedan? :-p
I have 215/75/r16s on my BRAT.
I have yet to test them on my OBS with Forester XT struts. I know that I will need to do a lot of fender trimming to get them to fit right.
The only problem I had with the BRAT was that I originally used OBS front struts and the tire would hit the lower spring perch. I put on a set of Outback front struts and they clear just fine.
BW
BW
...why can't you just say "yep, they'll fit no problem! you'll love it!"........pessimist
:-p
:-p
cause I am waiting for your to say that so I can go pick a new set up for myself. The current ones that I am running are TheyMightPops.... pick a part specials.
BW
TOO BIG!!!
i just called and they said that they didn't fit in the rear well.
they also said that they figured this out after they mounted all of the tires...i hope i don't have to get into a fight about getting charged for that. it's not my fault they didn't think to mount one and test it front and rear...
anyway, i'm now going with 205/75r15 Pathfinder Trail A/P which is only 1 size bigger than an outback, so i can't see there being a problem fitting.
TOO BIG!!!
For eyeballing my OBS set up. I know that I am going to have to trim the crap out of the rear fender wells, especially the side closer to the doors. Other than that it would be ok.
