brighton98 Posted September 4, 2007 Share Posted September 4, 2007 I finally had my RF cv axle replaced (good used Subaru), but now I have a vibration under braking, mainly from higher speeds. The steering wheel shakes from side to side, more violently the longer you brake. Also it oscillates the same on the highway >60mph. The axle seems OK, and I followed a chart posted by porcupine73 that points right to the rotors, which supposedly weren't touched during the axle job. I cleaned out the calipers & looked for obvious rotor wear, but found none. Could there be a corellation here, or just a coincedence?? As always, your thoughts are welcomed. Thanks! Link to comment Share on other sites More sharing options...
nipper Posted September 4, 2007 Share Posted September 4, 2007 Well lets back up a bit, make sure the tire is tight. It is possible that a bad axle was counteracting the vibration that was there before. Vibrations are interesting things. Can be a loose nut (not properly tightened) can be a bad tire, can be a warped rotor. nipper Link to comment Share on other sites More sharing options...
OB99W Posted September 4, 2007 Share Posted September 4, 2007 What was the source of the "good used" axle? If from a "yard", can you be sure that the source car wasn't in a front end accident? It's also important that all mating surfaces are clean; some grit or rust between parts can cause problems. I'd suggest checking rotor runout, but if you find some don't assume the rotor is the culprit until other causes are eliminated. Link to comment Share on other sites More sharing options...
nipper Posted September 4, 2007 Share Posted September 4, 2007 Silly me, i just went through this. Check the wheel bearing. Sometimes the "effort" to remove an axle can push an old wheel bearing over the edge. I just went through this with Blu, within one tank of gas the wheel bearing was shot. Blu had an axle replaced, and 210,000 miles on the original bearing. nipper Link to comment Share on other sites More sharing options...
brighton98 Posted September 5, 2007 Author Share Posted September 5, 2007 The CV axle is from a reputable Subaru specialist. The wheel bearing doesn't seem loose and doesn't make any noise. The shake is negligible at speeds under 50 mph, but always occurs under braking. Hope this sheds some light. Link to comment Share on other sites More sharing options...
OB99W Posted September 5, 2007 Share Posted September 5, 2007 brighton98 said: The CV axle is from a reputable Subaru specialist. The wheel bearing doesn't seem loose and doesn't make any noise. The shake is negligible at speeds under 50 mph, but always occurs under braking. Hope this sheds some light.As I've already suggested, checking runout of the rotor is a starting point. See the RUNOUT section of http://www.aa1car.com/library/2003/bf110322.htm Link to comment Share on other sites More sharing options...
